Results 1 to 2 of 2
Thread: trans cooling lines
    Feb 2003
    Grand Rapids MN 55744
    Default trans cooling lines
    Howdy
    On the 1986 k5 blazer radiator, what transmission(turbo 400) line is input?
    Transmission lines are on the driverside.
    I always thought the top was input, bottom out?
    I am adding a trans cooler.
    Thanks!
    2001 Chinook RV, V10 gas
    1967 GTO, 1989 Honda Transalp
    3 kids, 1 wife, 1 dog
    Trace the lines back to the tranny
    On the 350/400/700 the top fitting (at the tranny) is the return line.
    Normally the fluid feeds from the tranny to the top fitting on the radiator then returns from the bottom one.
    Be sure to get your air to oil cooler in the line that's returning to the tranny to give the best added cooling.
    If you have any doubt of flow direction, unhook the lines at the radiator, slip some fuel hose over them and stuff the ends in can, have a helper fire the rig for a second.
    ***** Safety*****
    Place tranny in N for best oil flow and set park brake/block wheels before starting engine
    You will quickly know which line delivers the oil.
    Good luck
    Missy
