Thread: 1997 GMC K3500 speedo not working
    Default 1997 GMC K3500 speedo not working
    I have a 1997 K3500 diesel. Trans was not shifting properly. I changed the speed sensor at the transfer case. Now trans is shifting ok. But now thw speedo does not work. It worked inaccuractly prior to changing speed sensor, but now it does not work at all. Does anyone have any suggestions to help solve speedo issue?
    Lubbock TX, USA
    Sounds like a bad VSSB Module, Research VSSB Module on google for a company called Unique Diesel, they remanufacture these.
    John
    1986 C10 SCLWB 6.2TD 3.73 700
    1989 V20 SUB 6.2NA, 3.73 400
    1994 G20 VAN 6.5NA, 3.42 60E
    1996 K30 DRW 6.5TD 4.10 80E
    thanks, I will check that out.
    Nov 2015
    georgia
    I just ordered a vssb from unique diesel today. John is very helpful. My vssb has water damage and some broken connections. I hope this will fix my shifting issues.
    Poor connection issues happen, but if your VSSB has water damage, you may have bigger fish to fry (maybe literally).
