Thread: Door hinge questions
    Sep 2015
    Default Door hinge questions
    I need new hinges for my 96 and also a new door latch mechanism what year will fit my truck ? The parts houses want 150 bucks for the latch so I was hoping to find one at a junk yard .
    Thanks Shaun
    1996 k2500 extended cab automatic trans electric shift transfer case reman engine with 70,000 miles reman trans 60,000 miles
    Feb 2003
    Grand Rapids MN 55744
    Howdy
    In my experience, re: hinge pins, unless you can find a known newer one in a yard you will likely have the same problems with any used parts.
    My neighbor is a salvage yard and he sells new hinge kits and latches.
    The cost is high and the hinge pins are a pain to replace but most of the new kits are better than what the trucks came with.
    Hope this helps
    2001 Chinook RV, V10 gas
    1967 GTO, 1989 Honda Transalp
    3 kids, 1 wife, 1 dog
    Sep 2015
    Thanks for the reply a freind stoped buy today and gave me a new latch so I've got the door so it'll open and shut now still debating on hinges becuase they are welded to the body I might just try putting a new pin and bushings in it
    Apr 2016
    Saint-Lazare, Quebec Canada
    Default Just finished that job
    I just completed swapping both pins and bushings on drivers side. Accrual hinges were fine and the dorman hinge pin kit worked well.
    Spring was a pain but I compressed it in the vice and locked it with tie straps. Have a helper for the door weight. I had trouble managing on my own and wifie had to help out.
