Thread: Retained acessory power on a 2003 2500hd
    Mar 2003
    Columbus In
    Default Retained acessory power on a 2003 2500hd
    I cannot find a source for a feed to a relay to contron a few acessories (sirius gps etc)
    I do not see any fuse that indicates retained acessory, and the ones that do control like the radio that should be retained, are on all the time. Must be before the timer switches the circuit. I do not see any fuses to control the power windows.
    Do I need to splice into a wire at the window or other timed device?
    The power windows fuse circuit should be a CB, and marked as such. I've used this circuit for many RAP needs with success. I normally use a piggy-back spade for access, but you could splice into the circuit behind the fuse block.
    Mar 2003
    Columbus In
    The circuit breaker for the power windows is hot all the time.
    I guess when I have more time, I will pull the radio and look at a line splice.
    Jun 2007
    Watkins, CO
    In a 2003, the RAP module is in the passenger side power window/lock control. I'd look for the feed from there.
    Bob
    tufcj
    Mar 2003
    Columbus In
    Where is that module?
