Results 1 to 17 of 17
Thread: Fuel Tank Sock Part Number
Hybrid View
    Default Don't do it!
    Recurring theme as of late. Aftermarket sender (with sock) and hair pulling headaches ensue.
    Aftermarket parts are often good, but more often inferior as has been the case here. Ask Casey (Arveetek) and I think there was one other that followed shortly after.
    Just took a call yesterday from a guy with a 93 and new aftermarket sender. Truck went like 200 miles then shut off with filter full of air.
    Feb 2012
    Pauline, SC
    John, do you know what brand it was, I have had very good results with the one I installed, hope it doesn't croke on me now....
    1993 Chevy K3500
    like us on Facebook
    May 2004
    Salem, Oregon
    Thanks all. I will pull it down and give it a good soaking and a wash as well as the tank and put it back together. If it is trashed I will order a new sending unit.
    BrentN
    1999 Suburban 2500 4x4
    176,500 miles,4.10,K & N Air Filter
    Kennedy 3.5" Exhaust, Remote Mounted FSD Cooler
    Kennedy Boost Fooler, Homemade Intercooler (Dieselpage Model)
    Derale Fan Cooled Tranny Cooler (under body mount)
    A Pillar Pod (Isspro Boost, Pyro & Trans Temp)
    2014 Cruze 2.0 Diesel- Tuned and loving it.
    Kerma TDI Tune (+35hp/75lb-ft).
    55.7 MPG best average thus far
    2008 Grand Cherokee, 3.0L Mercedes Diesel
    Tuned- 240hp/440lbs - Amazing out of a 3.0L
    1998 Dutch Star 38' Diesel Pusher, 8.3 Cummins, Allison 6 spd, 9.9-10 mpg
    Stock 300 hp/850 ft-lbs
    Yeah, it took me several months to figure out that it was the aftermarket "sock" that was squeezing down and shutting off fuel flow. I reinstalled the OEM "sock" and all has been good since.
    I don't know if you can even find an OEM "sock" by itself. Like the original poster, the only option I found was a GM sending unit assembly with an insane price tag.
    If you really do have a clogged OEM "sock", you should be able to take it off and clean it well with brake cleaner or some other solvent, and be back in good shape.
    May 2004
    Salem, Oregon
    Thanks Casey. Didnt get to the cleaning this weekend. Maybe this week. Always something coming up.
    BrentN
    Feb 2012
    Pauline, SC
    I found this....
    Part: Fuel Tank Sock
    Part Number: 25055272
    Manufacturer: ACDELCO
    1993 Chevy K3500
    like us on Facebook
    May 2004
    Salem, Oregon
    Thanks for the part number
    BrentN
    Jul 2003
    Allentown, PA
    Brent, if you have time, could you post as to "how" you went about dropping the tank and how it went for you? It doesn't look to be all that hard, but I sure wouldn't mind reading about your experience.
    Apr 2010
    Quote Originally Posted by DennisG01 View Post
    This isn't meant to sound cocky but:
    Drain or run tank to near empty, support tank (across broad surface like a slab of plywood and a floor jack), disconnect filler tube, disconnect feed/return lines, remove straps, lower tank.
    Remove tank sender/pickup unit by removing locking ring and lift out of tank.
    Install in reverse order.
    The rest is just spinning wrenches.
    Of course, you could just remove the bed if you find that an easier route.
    Like 6 bolts, the filler tube and some electrical connectors and it will lift free.
    Well, it will with a lift or 4 strong friends....
    1998 k2500
    Jan 2009
    I found this....
    Thanks sctrailrider
    Looks like my sock is clogged and turns out the RockAuto FSU i installed 2 years ago has a gas strainer/sock and NOT a diesel sock.
    So i had to order the GM # 25055272 sock from my local dealer for $36, it will be in late tomorrow afternoon!!!!
    Can you Yahoo
    BUT, WILL it work?? meaning, will my Dorman FSU # 692097 allow me to snap off the gas sock and pop on the GM sock, man i sure hope so???
    Rock Auto FSU
    http://www.rockauto.com/catalog/moreinfo.php?pk=1027202
    RockAuto.com has the ACDelco sock # TS1012 for $20
    More Information for ACDELCO TS1012
    BUT Get this, turns out that for me locally, only 1 company carries the diesel sock
    1 AutoZone can get it $29
    2. NAPA can NOT obtain the ACDelco TS1012
    3. CarQuest can NOT obtain the ACDelco TS1012
    4. Brandywine (local 6 group private parts store) can NOT obtain the ACDelco TS1012
    5. PepBoys can NOT obtain the ACDelco TS1012
    6. Advanced Auto Parts - can NOT obtain the ACDelco TS1012
