TheDieselPage.com Forums
2017 - TDP's 21st Anniversary
Go Back   TheDieselPage.com Forums > Chevrolet & GMC 2500HD/3500 Light Trucks > 2500HD/3500 HD Trucks & Drivetrain
Reply
Thread Tools Display Modes
  #1
Old 09-16-2017, 06:40 AM
brandongarnold02 brandongarnold02 is offline
Enthusiast
Default Refridgerent capacity for a 2005 Silverado 2500hd crew cab with a 6.0 LS?
Im hoping this is the right section. I am in need of the refridgerent capacity for this truck. The decal under the hood is not legible. This truck has the center console with the vents for the rear seats. Looked at several forums online and all I've read is without rear a/c it's 1.6 lbs but would when I think of rear a/c I think of a SUV with a separate evaporator and all in the back. This just has vents that tie in with the front ductwork. Anyway any advice or the refridgerent amount would be a great help. Thanks.
__________________
1994 Chevrolet K3500 Dually, 6.5 Mechanical Pump Conversion, NV4500
  #2
Old 09-16-2017, 07:25 AM
rapidoxidationman rapidoxidationman is online now
Enthusiast
Here's the specs for my diesel truck. Not sure what your gasser is rated at though.
In case the image doesn't show up: 1.8 pounds
__________________
'85 Mercedes Benz 300D, for when I want to be stately.
'05 Mercedes E320 CDI, for when I want to be even statelier.
'05 Chevy K2500 ext cab long box DMax: Everything my '03 was and so much more!
There's no point being a pessimist - it wouldn't work anyway.
  #3
Old 09-16-2017, 09:07 AM
DmaxMaverick's Avatar
Administrator
"Rear A/C" requires a separate evaporator for the rear. Rear vents in the console is not Rear A/C. Refer to the above chart and advice. R134A systems, especially older systems, usually need some adjustment when only "servicing". Some systems work better with more, others with less. Much depends on how much oil is actually in the system, and the overall condition of the components. Adding oil reduces the capacity for refrigerant, and it isn't uncommon for an older system to be too full of oil if several repairs/services have been performed over the years. It's nearly impossible to get it perfect unless the system is completely disassembled and flushed, then serviced according to spec. This is advised if the recommended service doesn't provide adequate performance.
__________________
  #4
Old 09-16-2017, 05:39 PM
Enthusiast
Thanks. I wouldn't think the systems would differ from a diesel to a gasser and as far as the history of repairs I would guess not much. It has 140,000 miles and all look to be oem parts under the hood. The high side fitting is leaking pretty bad and needs replaced.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
