TheDieselPage.com Forums
2017 - TDP's 21st Anniversary
Go Back   TheDieselPage.com Forums > Chevrolet & GMC 2500HD/3500 Light Trucks > Duramax 6600
Duramax 6600 Discussion Forum for the Duramax 6600 Diesel Engine, including the LB7, LLY, LBZ & LMM engine specific topics.
Reply
Thread Tools Display Modes
  #1
Old 09-24-2017, 06:21 AM
Naildriver Naildriver is offline
Newbie
Default Problem
I'm having a problem with my 06 duramax, when I give it pedal to accelerate it sounds like the turbo makes a squealing/grinding noise and hesitation in boost as soon as I let off it quits. Does anyone have any ideas on a fix
  #2
Old 09-24-2017, 07:30 AM
rapidoxidationman rapidoxidationman is online now
Enthusiast
Have you had a chance to check for engine codes? They could reveal what's up. Turbo leaks (loose hoses) can sound like squeaks and whistles too - make sure the plumbing is all snug.
__________________
'85 Mercedes Benz 300D, for when I want to be stately.
'05 Mercedes E320 CDI, for when I want to be even statelier.
'05 Chevy K2500 ext cab long box DMax: Everything my '03 was and so much more!
There's no point being a pessimist - it wouldn't work anyway.
  #3
Old 09-24-2017, 08:11 AM
Newbie
Default Problem
I have checked codes replaced turbo vane sensor and solenoid but I have not checked for loose hoses some people have said it may be bad turbo or a wastegate problem. I will check the plumbing.thanks
  #4
Old 09-24-2017, 02:31 PM
Enthusiast
You can also pull the intake pipe off the front of the turbo and try to move the hub. It should spin freely but should have nearly zero play off the axis. If you can spin it and push it against the walls of the housing...
__________________
  #5
Old 09-24-2017, 03:35 PM
Newbie
Default Problem
It will be tomorrow before I can check the things you mentioned but I will and thanks for the advice, I will let you know what I find
  #6
Old 10-10-2017, 05:11 PM
Newbie
I'm having a friend check out my truck he has done some checking and thinks that the vanes in the turbo are stuck all the plumbing is good
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright 1996-2017 by TheDieselPage.com - All Rights Reserved
