Results 1 to 9 of 9
Thread: Dual stat crossover on a 95 6.5 T/D
    May 2014
    us, ga
    Default Dual stat crossover on a 95 6.5 T/D
    Am I supposed to trim the tentioner bracket to make this thing fit? Thanks
    Sep 2003
    Feeniks, Aridzona
    I had to grind mine slightly. I got it just to the point where I could slip a business card between them.
    May 2014
    us, ga
    Anyone know the part number for Robert Shaw 180° thermostat?
    May 2014
    us, ga
    Talking
    I found 2 diffetent part numbers for Robert Shaw but have no idea if they will work or not
    330-180
    333-180
    Anyone know?
    My recollection is it's the 330. Could the 333 be for the dual setup?
    Edit: found this: " 333-180 Series Substitute Designed for Ford 351C with controlled bypass system"
    May 2014
    us, ga
    I have the dual thermostat crossover. I know there has been discussion into making sure you use Robert Shaw stats. I saw in a thread that Robert Shaw is also sold as "Stant"??
    Nope, two different animals.
    About 25 years ago Jim posted an article wherein he compared the various thermostats available for the (single stat) 6.5. The Robertshaw (one word) performed best.
    Sadly, it looks like they may be getting out of the automotive thermostat business. Found this.
    Kennedy still lists the the Robertshaw 180 stats (at a much better price than most places).
    Mar 2013
    USA,Pennsylvania
    I wanted to try a 180 degree stat in my earlier 6.5 single crossover and couldn't find one. What I did was take my 195 degree one and carefully cut the center out of it. Then I went to Autozone and bought a high performance 180 Degree off the shelf and tack welded it 4 places to the 195 degree one. Works great. The high performance one at Autozone has the same opening size as the Kennedy ones and should flow the same.
