2010 - TDP's 14th Anniversary
What's New: | Feature Articles: | Product Reviews: | Member's Area: | Join Us:
Duramax 6600 Diesel Page | Advertiser's Section | Classified Ads | Photo Album | Books
Go Back   TheDieselPage.com Forums > Other Diesel & Truck Related Forums > Diesel Fuel, Bio-Diesel & Fluids Forum
Diesel Fuel, Bio-Diesel & Fluids Forum Discuss and learn about Ultra Low Sulfur Diesel Fuel, Bio-Diesel, Straight Vegetable Oil, Waste Vegetable Oil, Fuel Additives, as well as Motor Oil, ATF, lubes, coolant and other fluids used in your diesel pickup.
Closed Thread
Old 01-15-2002, 11:57 AM
ryeguy ryeguy is offline
Contributor
Question
Any thoughts about fuel additives? I've got 6k miles on my '02 D/A now. A buddy is telling me I should be running some through with every tank to keep the injectors clean. This is after he had to replace a piston in his 6.5L (w/ 22k miles on it) after an injector clogged.
Thoughts? Opinions? Has this been discussed before? (likely)
--Rob
Old 01-15-2002, 12:08 PM
Alli-max Alli-max is offline
Contributor
FPPF total power or fuel power. Sometimes hard to find, but worth it. Truck stops sell it. Last a long time as well in a small bottle.
2001 GMC 2500HD SLE AlliMax, Longbed, Ext. Cab, 4X4 Summit White, G80 Differential, Husky Liners, Black UWS Toolbox, Black Westin Nerfs, Black Replacement Front and Rear Bumper, JL Audio, Hella, Cobra, Goodyear 265/75/16's, Tekonsha Prodigy Controller, Fumoto, Rhino Liner, 400 Watt Inverter
KENNEDY 4" Exhaust: INSTALLED!
UPDATED PHOTOS
My truck is faster than Pullinpower's. Period.
SoMnDmax...here I come!
I sure wished I lived in Lawton, OK so I could work on my truck in Mdrag's Shop!
Old 01-15-2002, 12:13 PM
D-max Man D-max Man is offline
GM does not recommend additives. Many use an emulsifier to blend water with the fuel so it can be burned, this will prevent the water separator from removing it. If the water is makes it past the water separator and is introduced to the fuel system parts it can cause rust and corrosion in the pump, injectors and other components. With the close tolerances of today
Old 01-15-2002, 05:21 PM
Tader Jack Tader Jack is offline
Contributor
Thumbs up
I've been using FPPF Total Power since September and also add some of their 8+ Cetane Booster to each tankful. I add 1oz. of each for each 5 gal. of fuel added at fill up, rounding off to the low side.
All I can say is this stuff does work. The truck runs better than ever.
Jack Schultz, McKean, PA
jackschultz@adelphia.net
http://photos.yahoo.com/bc/jack_schultz2001
2001 Chevy Silverado, 4-WD, 2500HD, Crew Cab, Short Box
LT Trim, Black Onyx w/ Tan Leather
Beltronics 980 Radar Detector
  #5
Old 01-15-2002, 06:24 PM
TnMax TnMax is offline
Contributor
The shop manager that services my truck told me GM will not warranty a Duramax fuel pump if there is evidence an additive has been used in the fuel. I was going to add an fuel additive for my trip to Kansas,but after talking to the shop manager I took the additive back to Tractor Supply and got my money back. Those diesel fuel pumps are expensives
  #6
Old 01-15-2002, 07:37 PM
Kennedy
Posts: n/a
I gotta say that policy is some of the STUPIDEST stuff that I've heard!!!
Just how many premium diesel stations do they think there are that do NOT use additive to make it premium???
Alcohol based additives (PS) are a definite no-no, but come on, when injection mfrs distribute the stuff...
John Kennedy
www.kennedydiesel.com
John@kennedydiesel.com
2002 Chev. K2500HD Dmax/Allison Crew Cab Long Bed Pewter/Tan LT Driving it!!!
1996 GMC K2500HD 6.5TD Ex.Cab LWB 260+ Rw H.P.
1984 K30 SRW 6.2NA Headers and custom 2 into 1 exhaust FOR SALE
'01 FXDWG Black/Chrome Yellow (2 into 1 Thunderheader <naturally&gt (100+ RwHP)
"If I had to explain, you wouldn't understand"
  #7
Old 01-15-2002, 08:45 PM
Trucker Tex Trucker Tex is offline
Contributor
You can get more misinformation from some GM service advisors on Duramax Diesels than you would expect from your average old maid librarian. Unfortunately, some of them don't know their a** from deep center field.
I've seen a GM bulletin at Diesel Injection Service endorsing the use of Stanadyne Fuel Additive.
2002 GMC 2500HD D/A, Crew Cab, Short Bed, Pewter with Pewter SLT Leather, Westin Stainless Nerfs, Line-X Bed Liner, Fumoto Valve. Run GM Synthetic Diff, Chevron Delo 400, Amsoil air filter, Stanadyne Performance Formula and Allison/Castrol TranSynd.
  #8
Old 01-15-2002, 09:23 PM
Bill McGouirk Bill McGouirk is offline
Contributor
I went on trip to the snow and got a can of STP fuel additive just in case it got to cold. I did not have to use it it was very warn. But I like the idea of better mileage and keeping the my truck runing great. So what is the right stuff to use? The cans all look the same.
Thanks BIll
  #9
Old 01-16-2002, 10:06 AM
a64pilot a64pilot is offline
Contributor
Bill,
Stay away from the stuff that claim they rid the fuel system of water for the reasons that D-Max man stated.
IMHO you are much better off leaving the water seperated and letting the filter do it's job.
2001 C3500 Charcoal Grey
Putco Boss Boards
Putco Virtual Grille
Stainless Sill Protectors
Stainless Exhaust Extension
SPA DG-111 Boost/Pyrometer
Whistler Radar Detector
600 Watt Inverter
Compaq Lap Top W/Moving Map
250 Watt Texas Star Linear Amplifier
Cobra 29 Classic CB Peaked W/Echo Card
102" Steel Whip
Cross Bed Aluminium Tool Box
Catch All Mats
  #10
Old 01-16-2002, 10:36 AM
Contributor
FPPF. As I said above, Some truck stops sell it, and you can also check out www.kennedydiesel.com Get his number, and give him a call.
UPDATED PHOTOS
Closed Thread
vB code is On
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright 1996-2010 by TheDieselPage.com - All Rights Reserved
