Closed Thread
Old 12-24-2003, 08:40 PM
64postcarnut 64postcarnut is offline
I'm familiar with the hp loss ratio of 4%/1000ft as it applies to a gas engine.So,here in Denver I lose 20-24%.
Does this same rule apply to diesel engines?
\'04 GMC,White,EC,4x4,LB,D/A<br /><br />Dave Walters<br />Aurora,Co.<br />whdavid@qwest.net
Old 12-24-2003, 10:24 PM
FisHn2DMax FisHn2DMax is offline
Yes, there is altitude power loss in a diesel. However, based on my own personal experience, the altitude loss is not as pronounced in a Diesel? I live and drive in a high altitude mountain area in Utah. My diesel doesn't seem to lose much power compared to my gas vehicles in higher mountain passes? My theory as to why is due to how the Diesel burns, and the use of a turbo. Maybe someone here can explain the exact science as to why the Diesel doesn't seem to follow the gas altitude power loss rule of minus 4-6% HP per every 1000' rise in elevation? The diesel like all piston engines will have some power loss the higher in elevation.
Good Luck!
2003 GMC 2500HD SLT Crew Cab 4x4 D/A with all the toys! Rear seat DVD system with Bose 6 changer CD Stereo system. factory Extendable tow mirrors. Line-X sprayed bed liner, Westin Nurf bars, 285 BFG AT\'s on 16\" AR chrome pythons, 5\'er hitch, prodigy controller.
Old 12-25-2003, 05:29 AM
Idle_Chatter
Guest
Posts: n/a
The reason that the diesel loses less is the basic principle of the engines. The gasoline engine uses a fuel/air mixture, which is either generated volumetrically in a carburator or throttle body. When the number of air molecules per volume decreases at altitude, the computer is "fooled" by the equal volume. The diesel compresses a fixed volume of air and then injects fuel at full compression. The reduced air concentration has a lower effect at compression than at ambient conditions. The diesel is also more fuel-efficient, getting more BTUs per unit out of the fuel, which also aids in minimizing the effect. I suppose that the mass air flow sensor will make the diesel run a bit rich, but most diesels don't mind that, they just smoke a bit and rumble on! The air/fuel mixture in a gasoline engine is much more sensitive to losses when running rich or lean.
Old 12-25-2003, 06:21 AM
SoMnDMAX SoMnDMAX is offline
A turbo diesel shouldn't lose much power, if any. As altitude increases, the air gets "thinner", like Tom said- less molecules per volume. This "thinner" air allows the turbo to spin FASTER, creating the same amount of manifold pressure as you would see at say, 800 ft. That is the beauty of a turbocharger.
Put a turbo on a gas engine, you can see the same results- namely snowmobiles. Folks turbocharge mountain sleds all the time to negate the effects that altitude have on tuning and power production. The turbo not only boosts power significantly, but the sled will not lose any power as it goes up the mountain side.
2003 Chevy 2500HD LT EC/SB D/A <br />Dark Gray, loaded..<br />Kennedy 4\" Exhaust, Headlight Harness, Access, Air Lift, Luverne, <br />Hot Juice, Mega Filter, more....<a href=\"http://community.webshots.com/user/somndmax\" target=\"_blank\">Pics</a><br /><a href=\"mailto:somndmax@yahoo.com\">somndmax@yahoo. com</a>
  #5
Old 12-25-2003, 01:18 PM
McRat McRat is offline
Yep,
Since there is less air being drawn in each cycle, the gas engine injects less fuel, and makes less power.
With a diesel, it still draws in less air at high altitude. But most diesels DON'T inject as much fuel as they can at WOT. There is actually "unused" air in the cylinder after it fires. This is how the chips work, they inject more fuel to take advantage of the "unused" air.
Then the turbo. It will ram in nearly the same amount air regardless of altitude. Yes it does lose some boost, but not as much as Naturally Aspirated motors do. Belt driven superchargers DO lose significant HP at altitude if they are not overdriven (wastegate design). Turbos generate boost by engine load, while regular supers are RPM dependant.
Tuner of fast "diesel" powered trucks, www.McRatRacing.com
2005 GMC 2500HD "Casper" 11.77 @ 114.5 on #2. 674rwhp, 1380tq. EFILive "McRat" tuning, Mike L Suncoast, PPE Dual CP3's, HighTechTurbo "McRat" charger.
2004.5 GMC 3500 "Big Blue" 13.1 @ 103 on #2. PPE Tuned, Mike L Suncoast Trans.
2006 GMC 2500HD "Wendy" 13.9@96 on #2, PPE tuning, Mike L Suncoast trans.
  #6
Old 12-25-2003, 03:50 PM
dmaxalliTech dmaxalliTech is offline
The Dmax uses a Baro sensor that should be able to compensate somewhat for altitude changes.
2003 GMC Sierra 2500 HD CC Shorty
Dyno Proven - 800 rwhp on fuel only.
Trans to hold it and a big ol S400 turbo feeding it.
  #7
Old 12-26-2003, 07:29 AM
KevinK KevinK is offline
I asked the same question over on the TDR a couple of years ago and was told by one person that the loss is about 0.5% per 1000ft due to less oxygen (basically what was said above). I have noticed that as you gain elevation, you lose boost. While I hit 30lbs. around town, I only hit maybe 28 (or less) at higher elevations. The biggest affect I've noticed is higher EGT's. If you've got a chipped truck, the EGT's can quickly get to 1400 or 1500 on a hard pull. I can run only about 1/2 throttle up the passes on I-70 because of it (pulling a 10k trailer at 60-65).
Pulling roughly the same weight over the same passes, my stock diesel (at the time) would run cricles around my modified 454.
Kevin
</font><ul type=\"square\"><li><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">2k Dodge 3500 CTD, auto, SLT+, Quadcab</font></li><li><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">DD2 injectors, Power Edge Drag COMP fueling/timing box, DTT tranny upgrades, PDR35 turbo, 4\" exhaust, K&N, Line-X liner, Reese 15k hitch</font></li></ul><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
  #8
Old 12-26-2003, 08:49 PM
BlueOx03 BlueOx03 is offline
You could run into a slight if even noticeable loss of power if you drove strait from a low altitude to a high one without shutting down. Like Eric said the D-max uses a barometric sensor to detect and compensate for low barometric pressure. The barometric pressure is read at key on, before the engine is started via the boost sensor. As stated before though, it shouldn't be any big difference.
03 GMC Sierra 2500HD D/A CC SB
Closed Thread
