Duramax 6600 Discussion Forum for the Duramax 6600 Diesel Engine, including the LB7, LLY, LBZ & LMM engine specific topics.
Old 02-02-2006, 04:00 PM
markrinker
Guest
Posts: n/a
I have yet to even pull the top plastic cover off my Duramax, but wondered if someone in the know could explain how the wastegate actuator works?
A quick glance today looks like it picks up boost from near the intake manifold and opens up the wastegate at a predetermined pressure to bleed off boost.
Wow...the 6.5 engineers sure overengineered boost control...(vacuum, sensor, solenoid...)
I bought a cheap boost valve that goes inline to fool the actuator. Must be a restrictor of some sort?
Old 02-02-2006, 08:29 PM
Tough Guy
Guest
Posts: n/a
Yes, the wastegate is pressure actuated...Kennedy has a nice little gizmo that "fools" the wastegate actuator.
The 6.5L truly is a engineering "gem"...
Chris
Old 02-02-2006, 11:46 PM
DmaxMaverick's Avatar
Administrator
In spite of the engeering nightmare, the 6.5 wastegate control is far better, when working properly.
The LB7 wastegate will bleed off exhaust pressure as manifold pressure rises. This wastes energy, and causes a falloff of peak pressure.
The 6.5 wastegate control, on the other hand, will hold the wastegate closed until the trigger pressure is reached, then dumps the exhaust pressure to maintain it. On/Off. Way better. This is what JK's boost valve does, on the LB7, and it's adjustible.
Active control is almost always better than a passive control that relies on spring load, but the simplicity factor can win out.
Old 02-03-2006, 06:32 AM
markrinker
Guest
Posts: n/a
JK how does your LB7 boost valve work? Is it a restriction to the factory line, or does it employ a check valve and spring to bleed off boost and maintiain peak as described?
  #5
Old 02-03-2006, 09:42 AM
mcmonroe
Guest
Posts: n/a
How is boost controlled on both the LLY and the LBZ? Via wastegate as well?
Mark
  #6
Old 02-03-2006, 11:22 AM
Administrator
Quote:
Mark
LLY/LBZ doesn't have a wastegate. The exhaust pressure is controlled by the VGT. The exhaust gasses are directed into the turbine by vanes, which are controlled by the PCM.
  #7
Old 02-03-2006, 05:11 PM
Kennedy
Guest
Posts: n/a
Quote:
You really need to get around a bit more:
http://www.thedieselpage.com/reviews/jkboostvalve.htm
  #8
Old 02-04-2006, 10:14 AM
markrinker
Guest
Posts: n/a
I read that long ago - have you sold your million of 'em yet?
The $28 Ebay purchase I made is simply a restriction to the line. Not adjustable. I may relist it and buy one of yours after testing to see what pressures I get with this one.
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
What would you say the effective range of peak pressures are - with your adjustable unit - with stock fuel rate, exhaust, etc. ???
[ 02-04-2006, 07:28 PM: Message edited by: Mark Rinker ]
  #9
Old 02-05-2006, 11:00 AM
Kennedy
Guest
Posts: n/a
From little/no change to mid 30's which is too much for the stock turbo.
Adding the boost valve to the stock program/fueling will not give much if any power increase. You need the exhaust heat and throughput to make the boost come up. Put a little fuel on it with an Edge box and watch it do it's magic!
  #10
Old 02-05-2006, 11:10 AM
markrinker
Guest
Posts: n/a
My propane tank should be here this week and mounted/filled by week end.
The plan is to put all hardware, and software and your electronic EGT/boost gauge in place, and take the following measurements:
1) Stock EGT and boost - as a baseline
2) EGTs and boost with propane - MSD factory settings
3) EGTs and boost with inline restrictor
The next few weeks will be used to detail the mileage and power affects of running propane over diesel while towing. Hope to capture lots of statistics.
JK I may become an EFI Live customer if my testing leads me to modifying the OEM fuel map for the LB7. I am interested in reducing diesel and increasing propane proportions while in tow/haul mode ONLY. Is this possible?
