One word of caution. I looked into using the add-a-circuit for my air bag compressor. The compressor takes 15 amps. The add-a-circuit is only rated to 10 amps; you could do some melt down. Also be careful which fuse you plug into. EVERYTHING in all 3 fuse boxes is monitored by the computer. If you seriously change the amperage being used on the circuit, the computer can shut the circuit. Dealer told me of 1 guy who plugged in his driving lights into 1 of the fuse plugs and would have to hold the key at start for 10 seconds before it would start. Guauges aren't a problem, but be carefull about higher amps.
2002 Silverado 2500HD,D/A,LS,ext cab,4x4,pewter,Truxedo cover,Line-X liner,Lund running boards,Bilsteins on all 4 corners, Air Lift air bags, Tekonsha Prodigy brake controller<br />2001 Honda Goldwing, pearl blue, 118 hp<br />2001 Coachmen Royal 32 ft travel trailer, double slide-outs<br />Toy Trax bike loader
