Can someone tell me the correct foot-pounds of torque needed for the lug nuts on a 2002 3500 dually with the OEM stock steel wheels? They don't seem to give that information in the owner's manuals. Thanks.
Marquitos
Marquitos
175 lb ft for dual wheels.
On a similair note:
What are you all torque setting for the PYO rims?
120 ft. lbs.
I also use this number for my 16x8 Centerlines...
PICTURES
2001 Chevy 2500HD Duramax, Allison, Ext. Cab SB Forest Green,
285's and Centerline's put away till spring... Now equipped with Goodyear Workhorse Extra Grips, 265/75-16 on the PYO's
Autometer Boost and EGT gauges, Amsoil air filter, Access Tonneau, Luverne Stainless boards, JL Audio 12" sub, Phoenix Gold, Clarion speakers...
Kennedy Diesel Headlight Harness, 70W low's, 100W highs... Bright Light!!
4" Kennedy Diesel exhaust installed!!
120HP VanAaken/TS Performance module from Kennedy Diesel
Diesel Page member #6184
Thanks SoMnDMAX.
Did you get that info from the user or service manual?
the service manual says 175 lb ft for dual wheels and 140 lb ft for all single wheels.
[This message has been edited by gmsi (edited 01-11-2002).]
Owners manual says 140 for 2500HD, does not specify for steel vs aluminum wheels though.
2002 Chevy 4x4 CC D/A
Jayco 325BHS
http://www.PictureTrail.com/maburns
Back to the top....
During my rotate & balance today I found the following:
Dealer 1 - don't go over 100 ft lbs
Dealer 2 - 120 ft lbs 'I think' he says
Dealer 3 - 140 ft lbs
The owners and shop manuals state 140 for singles (doesn't specify steel or PY0 - Aluminum)
The Sears store last time I went said 90 ft lbs, today it's 140 ft lbs.
What B.S. this is !!! All I want is to maintain the truck properly and even dealers can't agree.
Anybody else use a different number?
I plan on going with 120 ft lbs and waiting to see what others are doing.
Chevy K2500HD D/A LT EC/SB Green - Everything but the camper mirrors !!!!
Rubber mud flaps | Trac-Rac with canteliever | Rhino Liner | Bearcat CB/K40 antenna | McKesh Towing Mirrors | Fumoto Drain Valve | VENTSHADE Bug Guard, Window Defl, Step Shields | Prodigy Brake Controller
AMSOIL: 15W40 Syn HDD | Syn ATF | Series 2000 Syn Gear Lube (75W-90) | Syn Racing Grease | Cetane Boost & Diesel Additive Conc. | Dual-Remote BMK-13 (SDF-26&BE-100) | TS123 Air Filter
BFG LT245-75R16 ATko 'E'
http://www.picturetrail.com/gm-guy
Page 3-94 Vol 1 of 5 2001 Helm's manual agrees with numbers in above posts:
Dual wheel nuts 240 N-m 175 lb-ft
Single wheel nuts 190 N-m 140 lb-ft
Spare tire hoist retaining bolt 40N-M 30 lb-ft
mdrag
'01 3500 "BIG DOOLEY" DMAX/ALLISON PICTURES<UL TYPE=SQUARE>
<LI>2001 3500 LT Crew Cab/LB7 DMAX 6600/M74 Allison 1000 Series/4x4 G80/Light Pewter/Tan Leather
<LI>12 Disc CD Changer/Escalade Steering Wheel Audio Controls/Pioneer TS-C1653 Component Speakers
<LI>Kennedy Diesel Headlight Harness with 4 Lamp Mode/Dual Alts with PowerMaster 200A
<LI>TransferFlow 56 gal tank w/Fast Fill fillneck/ROSTRA Obstacle Sensing System
<LI>Roll-N-Lock Retractable Bed Cover with Carbon Fiber Pattern/TracRac Sliding Rack System
<LI>Clifford AvantGaurd4 Alarm with Remote Start/SmartWindows4/Computer Interface for MS Windows/Turbo Timer Option
<LI>SPA DG-111 Digital Boost & EGT Gauge/PIAA Airdam/PIAA 80 Pro XT Driving & 959 Fog Lights
<LI>DTA Corp Running Boards & Mudflaps/Line-X/Invinca-Shield/Center Console Mods
<LI>Lucerix X-Mount Mirrors/Tekonsha Prodigy/Goodrich Velvet-Ride Shackles
<LI>Future Mods Include: Alcoas, 4" Exhaust, Performance Module.... etc.[/list]
Just got new Centerline wheels a couple weeks ago(Comet III's, 16 X 8). The tire shop (reputable) torqued them to 100, as he said they do for all 8 lug singles. I thought it should be more, so I read the paperwork that came with the new wheels. It recommends 85 to 95 (??). I left them at 100, confident I had sufficient overkill. Now I'm not so sure.
175 on the duals sounds right. I've done that for years, but only on steel wheels. Don't know what aluminum would be.
2001 GMC 2500HD SLT 4X4 E/C SB loaded -D/A- Indigo Blue - Amsoiled bumper to bumper - Delivered November 2000
1985 K Blazer 6.2L N/A 500K+ original miles on Engine/Tranny (2 transfer cases, 1 pump, and a few rear ends)
Synthetic Oil!!
MDrag......LMAO..
You have to get a hold of yourself...You are starting to cite information like an attorney.....
Section 3-94 of the 2001 Helms...........
Sounds like this, In accordance with Statute implied in Jones Vs Smith, the plaintiff was deemed clear to proceed with cross as per section 11-32 of State Penal code, wherein such as, in leiu of.....Your Witness counseler....HAHAHAHAHAHAHA.
OBJECTION...OVERRULED!
On a closing note...
Thanks for the information....it is the same for Dually's...Ooops Dooley's...as it has been since 93-94 I believe. Even with Alcoa's the Torque requirement is the same. Hopefully none of you experience a road side repair and try and take off the lug nuts with a 3/8 drive and 9" extension....;D
Jeff
2001 Chevrolet K3500 4x4 LS
Duramax/Allison
Crew Cab
Long Bed
Victory Red
Light Grey Leather with Bench front
G80 Rearend
E-mail: DuramaxDually@onebox.com
Homepage. www.j-line-racing.cityslide.com
Torque em tighter, maybe you'll go FASTER !?!?!
While your at it, dont you think you should change the air in the tires??? It must be getting pretty old by now???
But seriously now, this is a serious matter, that very few dealerships or tire shops adhere to. I've never seen a torque wrench at any tire shop!
Thomas J. McCauley Jr.
Tommy's Lawn Service
Member # 5589
1990 K3500 SRW Ext.Cab Long Bed 454/400 3.73
1975 K20 Suburban 350/350 4.10's
Tows 16' Landscape Trailer
BOSS 8'2" V-Plow
7-11 MPG !!!
Duramax here I come!!
NorCalDMAX,
That's REALLY depressing me.......You are starting to cite information like an attorney...
Lawnboy,
...I've never seen a torque wrench at any tire shop!
I'd switch shops if they do not use torque wrenches. Improperly torqued lug nuts are a potentially HUGE problem. They even have them thar tork renches in OK.
mdrag
MDrag,
You know I got to thinkin bout that lawyer crack and want to retract it.
I forgot just how Shallow, sleezy, cheap those people are. Especially the "Contingency" attorney's...they are the worst..they are why our auto insurance is so high...
Please accept my apology....
I am instructing the JURY to disregard the comment setforth by NorCalDMAX in regards to MDrag and the attorney statement...HAHAHAHAHA. That is speculative and leading.....
Jeff
Duramax/Allison
Crew Cab
Long Bed
Victory Red
G80 Rearend
[This message has been edited by NorCalDMAX (edited 01-15-2002).]
The reason you don't see different torques for the PYO Aluminum wheels, as you usually will for alloy wheels, is that the PYO's have steel inserts at the holes, for the lug nuts to torque down on.
Waiting for...2002 GMC 2500HD CC D/ZF SB Summit/Graphite 2WD
Ordered 7/23/01 TPW 11/05/01 CANCELLED 12/13/01 (Day 153).
Orderred Again 1/3/02...Fire Red/Graphite this time.
Driving 1991 GMC Sierra 1500 V6 5sp 2WD LB 172,000 miles 22-25 MPG
This is not a fast truck!
NorCalDMAX,
I feel better now. But you do have a point, a too dry and technical post, not even a smiley - I'll try and do better. I HOPE THE TEACHER DID NOT SEE THAT ONE......I forgot just how Shallow, sleezy, cheap those people are.
mdrag
MDRAG.
Could you put DUAL lug nuts on each rim. (16 lugs) Just thinking if 8 is good then 16 would be better!
In Ontario, were we have all the Laws to protect us from ourselves, to install or mount a truck tire you must complete a provincial coarse first. They state that over torque is worse than under torque, because in a over torque situation lugs become brittle and can snap off under stress. All installations must be torqued. Then after installation you must return after a 100 km to have them retorqued. When I had tires put on my car, at Wal-Mart, the mechanic torqued them then the counter person went in to the garage and rechecked all his torques again, and I had too sign, that I would return to have them retorqued after 100 km. My dealer clearly stated that 140 lb was the number for my truck.
Bob
2001 2500HD 4x4 CC/SB LT Duramax/Allison Summit White
In addition to the recent string:
http://forum.62-65-dieselpage.com/ub...c&f=7&t=002953
I wanted to bring this issue up again. Some of the
contributors have been insistant that the torque
be at 175 ft lbs, however I just had my 2002 dually
tires rotated at 7500 miles at the dealer. I made
him check with GM and they say that the "new style"
lug nuts should be torqued to 140 ft lbs....no more.
I don't know when the "new style" lug nuts
came into production, but since my truck is 3
months old.... I'm going with their current
recommendation of 140 ft lbs.
Does anyone have the Helms manual for the 2002
models?
02 Chevy 3500HD, D/A, 4x4, Lucerix Mirrors, Fumoto valve, Amsoil air filter, <br />Kaydenco mudflaps, Hadley Air Horns, Lund Hood Protector, Prodigy,<br />2 micron Racor Post OEM fuel filter install photos:<br /><a href=\"http://community.webshots.com/album/66562661oghYok\" target=\"_blank\">http://community.webshots.com/album/66562661oghYok</a>
My manual for the 2002 Chev. 3500 dualy clearly states 140 ft.#
