Closed Thread
Old 10-26-2002, 08:33 AM
RVGuy's Avatar
RVGuy RVGuy is offline
Unhappy
I haven't owned many 4 wheel trucks and I've never experience anything like this before.
While in 4 wheel "Hi" postion, and when turning either direction full lock, the drivetrain seems to lock up and it takes considerable pedal to make the truck go. And when it does go it launches as if I had released the brake.
And no, I'm not depressing the brake while doing this. [img]tongue.gif[/img]
Is this normal operation for this truck??
Jim<br /><br />Silver Grey 2008 Silverado, LTZ,CC,4x4,dually, D/A, Fumoto, Rhino Liner, Garmin Nuvi 660, Edge Juice
2007 Mobile Suites Deluxe 5th Wheel RV
Old 10-26-2002, 11:27 AM
battmain battmain is offline
Yup. Try switching back to 2wd if you have to turn or increase the turning radius so you don't have to turn as hard. I usually switch to 4wd once the trailer is straight.
[ 10-26-2002: Message edited by: battmain ]</p>
2001 Torreador Red 2500HD GMC Sierra Ext Cab Longbed. 6.0L 4x4. Deep Tinted Glass with Defogger. Weathertech Ventvisors. Sony Xplod 6.5 front speakers. 8\" Bazooka waiting to be installed.
Old 10-26-2002, 11:31 AM
ZFMax ZFMax is offline
While turning in 4 wheel drive, the front and rear wheels need to turn at different speeds. With no slip device in the transfer case, you get exactly the symptoms you're reporting.
In general, you don't want to use a locked 4wd system on clear pavement, and you especially don't want to make a turn under high traction conditions. You will tear up the running gear in a hurry. 4wd is for icy or dirt roads only. On patchy icy roads, I'll often go back and forth depending on the condition of the road I'm on at the moment and whether or not there's a need to make a turn.
[ 10-26-2002: Message edited by: ZFMax ]</p>
Old 10-26-2002, 05:06 PM
RVGuy's Avatar
Smile
Thanks for the information. I feel much better now. I'll be switching back to two-wheel when making sharp turns.
  #5
Old 10-26-2002, 05:26 PM
letsgo letsgo is offline
RVGuy
As a first time 4x4 owner I had to ask the same question 10 months ago, like you I got lots of good info from the members.
Now I only use 4 wheel drive in snow and when I accelerate in rain from a stop, and when towing into camp sites with either gravel, grass, sand, but not on ashfalt.
good luck
GMC 2002 DURAMAX, SLT, EXCAB SHORT BOX 2500HD, 4X4, AUTO
ACCESS TONNEAU COVER, 3" STAINLESS TUBE STEPS
JORDAN BRAKE CONTROLLER
34ft 10,000 lb TRAILER, 50 GAL TRANSFERE FLOW TANK (total 76 gals)
  #6
Old 10-27-2002, 07:27 PM
ThePend ThePend is offline
RV Guy.... Its normal for this to happen. I had an F350 that would do the same thing. Then I found out that you shouldnt engage the 4WD on dry pavement and do a full lock turn, thats a no-no.
Since I dont go off roading very much, I usually wait until it rains and engage the 4WD then to keep everything turning.
2002 Chevy 2500HD CC SB 4x4 LT, Charcoal/Graphite, D/A, Locking Diff, HD Trailering, Skid Plate, Firestone 265\'s, Bilstiens, Banks Exhaust, BedRug, XM Radio, KD Headlight Harness, Retrax Bed Cover. Recent add-ons: Juice, Predator.
  #7
Old 04-09-2003, 07:16 PM
SPICER SPICER is offline
I was climbing a muddy hill today in 4WD. When I got out of the mud I forgot to take her out of 4WD. I drove on dry pavement for about 6-7 miles. I didn't realize it until I took a hard left and she felt really sluggish, like the E brake was on. I turned offf the 4WD. The front diff. felt warm, not hot. I took about 6 turns during this time. The manual simply says that accelerated wear may occur if left in 4WD on dry pavement for a "long time". Any comments, any experts? Ironically I just changed both diffs. a week ago to, Mobil1 synthetic. I have not changed the transfer case yet...6300miles. SPICER
2003 SILVERADO 2500HD CREW CAB DURAMAX, DELVAC1
  #8
Old 04-09-2003, 09:25 PM
dmaxalliTech dmaxalliTech is offline
spicer, dont worry about it, if your feel the need, pull your fill plugs and check fluid condition. IMHO, you'll be fine
2003 GMC Sierra 2500 HD CC Shorty
Dyno Proven - 800 rwhp on fuel only.
Trans to hold it and a big ol S400 turbo feeding it.
  #9
Old 04-09-2003, 09:48 PM
dmexalliTech,
Thanks for the reassurance. What would I look for if checking the condition of the fluids?
Just for education sake, what happens if you do run for a "long time" in 4WD on dry pavement? What components take a beating?
And, now that I have your attention, when should I change tha electronic transfer case fluids? I changed the front and rear at 6000mls. and used mobil1(switched out the front vent cap to white also). Thanks, and if you are a dmaxalliTech your oppinion is not humble....it is expert. Use IMEO next time!! SPICER
  #10
Old 04-10-2003, 07:52 AM
Jelisfc Jelisfc is offline
SPICER, the whole drive train gets bound up since almost no slip is allowed. Long term parts would wear out quicker. I doubt the added loads are such that anything would break immediatley. CV and or u-joints certainly would take a beating. Fluids are not a worry.
Real life example. I used to drive a 6x6 military 10 ton semi tractor. A different driver left the front axle engaged. I jumped in and drove down dry pavement. The drive train got so bound up something had to give. The front wheels were trying to turn faster than the rears and due to the added weight on the rears the front end actually started hopping left to right. As it did the tires would break traction and unload the drive train. Heck of a ride when that happened. It was all I could do to stop it from 30 mph.
I doubt that would ever happen on a pickup since the weights are less and more balanced.
2003 GMC 2500HD, DMAX/ZF 6 gear, 4X4, CC/SB, Carbon Metallic, <br />pre OEM CAT filter, H2 wheels & tires. <a href=\"http://community.webshots.com/user/jelisfc\" target=\"_blank\">Pics</a>
Closed Thread
