Closed Thread
Old 12-11-2002, 09:45 PM
56Nomad 56Nomad is offline
What is the difference between the Stud #1 and Stud #2
locations in the fuse/relay block? Do they work independently
or is there some commonality between them.
Stud #1 Accessory Power/Trailer Wiring Feed..............takes a 40 amp fuse
Stud #2 Accessory Power/Trailer Wiring Brake Feed....takes a 30 amp fuse
I put the 30 amp fuse in Stud #2 when I had the Lance camper harness installed.
Now I just purchased an electric brake controller to install for our new
trailer and I will need to put the 40 amp fuse in Stud #1 to make it work.
What do each of them do?
Can one of our electrical guru's simplify this for us........I'm confused
02 Chevy 3500HD, D/A, 4x4, Lucerix Mirrors, Fumoto valve, Amsoil air filter, <br />Kaydenco mudflaps, Hadley Air Horns, Lund Hood Protector, Prodigy,<br />2 micron Racor Post OEM fuel filter install photos:<br /><a href=\"http://community.webshots.com/album/66562661oghYok\" target=\"_blank\">http://community.webshots.com/album/66562661oghYok</a>
Old 12-11-2002, 10:39 PM
NoMo NoMo is offline
Question
I believe it's something like this:
Stud #1 charges your camper battery.
Stud #2 powers electric trailer brakes.
2003 Sierra 2500HD SLE EC 2WD Short Box D/A
Old 12-11-2002, 10:47 PM
NoMo,
I think you have it reversed????
Old 12-12-2002, 01:05 AM
DonG DonG is offline
56Nomad,
I think NoMo is correct, at least on my 2003 3500 he is correct.
The data you posted suggests that also...
"Stud #1 Accessory Power/Trailer Wiring Feed..............takes a 40 amp fuse"
"Stud #2 Accessory Power/Trailer Wiring Brake Feed....takes a 30 amp fuse"
Don
2003 GMC 3500 SLE, D/A, EC, LB, 2WD, White/Pewter, DeeZee boards, 5th wheel
  #5
Old 12-12-2002, 08:19 AM
4x4man 4x4man is offline
Cool
NoMo and Don are correct.
The 40amp fuse that is located in Stud #1 powers your 12 volt constant. When you have a fuse in there, it sends 12 volts to your plug by the receiver and in the bed (if you have that option)
The 30amp fuse located in Stud #2 is what powers the brake controller harness for your brake controller to work.
This is the case for the 03's.
Bob
2003 GMC 2500HD 4x4 CC SLT D/A, fully loaded!!<br />Upgrade\'s so far:<br />265x75 R16 Pathfinder ATR\'s, Westin CPS Nerf Bars, GM Mud Flaps, 3M Clear Bra, Line-X, Reese 20K Hitch, Prodigy Controller<p><a href=\"http://www.webphotos.com/list_photos.asp?mi=3&smi=1&a=97210\" target=\"_blank\"> My Truck</a><br /><a href=\"http://www.webphotos.com/list_photos.asp?mi=3&smi=1&a=93738\" target=\"_blank\">Our Fifth Wheel</a>
  #6
Old 12-12-2002, 10:43 AM
Thanks for that info.....
This must be the reason that the 2003's were a little
more expensive than the 2002's
I wonder why they would switch the positions on
Stud #1 and Stud #2
  #7
Old 12-12-2002, 12:37 PM
Professor Professor is offline
Same reason the switched the *#&%$ Trailer controller connection
82 6.2 1/2 ton Energizer Version 359,000 Miles and Counting!
99 GMC 2500LD 6.0 That wants to be a D-Max when it grows up!
  #8
Old 12-12-2002, 12:55 PM
Smile
I was just going off the descriptions you gave for each fuse position. I haven't checked for myself to see which one powers the battery and the brakes. [img]smile.gif[/img]
  #9
Old 12-14-2002, 06:15 PM
AbqGeorge AbqGeorge is offline
The puzzle for me, and this was with both my '01 and '03 is that the truck comes with the fuse already installed for the brake controller. I know of at least one person (who shall remain anonymous [img]smile.gif[/img] ) that blew the fuse while mucking around wiring up his brake controller. He thought the fuse included with the wiring harness was to provide power to the brake circuit. NOPE, that fuse goes into STUD 1 position (both '01 and '03) and provides +12 volt power to the trailer connector. ALL trucks ordered with the trailering option do not come with the B+ fuse installed.
Weird???
2003 Silverado 2500HD EC SB 4x4 D/A, Jordan 2020 Brake Controller,<br />Transfer Flow 45 Gal., Reese 16k FW hitch, 2001 Sunnybrook 27RKFS FW
Closed Thread
