Old 04-04-2006, 09:04 AM
2ortman 2ortman is offline
Newbie
Default Air intake conversion
Greetings, I am a new member to this community. I am the original owner of a 1994 3/4 ton Pickup. It has a standard transmission with a 6.5L turbocharged engine. It has very low miles, and is used mostly for hauling a camper around in the summer. Right now I am upgrading the engine air flow. On the intake side, I have been told that the stock airbox can be swapped to a 1997 1 ton high capacity, which will fit a Trueflow filter. I am also upgrading the exhaust to a Banks system which includes a superscoop for the intake, and a so if it works I should get a larger volume of cool air to the intake. The other option was to use an AFE filter assembly, but it seems to me that since this assembly is basically an open filter in the engine copmpartment it would result in sucking hot engine air rather than cool outside air. Does anyone have experence with this? My main question is wether the 97 air box will fit into the 94 truck. Any other ideas? Thank You for your help,
Jim Ortman, Bozeman
Old 04-04-2006, 10:45 AM
Bnave95's Avatar
Bnave95 Bnave95 is offline
[ ........Right now I am upgrading the engine air flow. On the intake side, I have been told that the stock airbox can be swapped to a 1997 1 ton high capacity, which will fit a Trueflow filter.........
This works better than stock box yours and mine has, though the aFe that fits our boxs work very good in air flow and filtering.
....... I am also upgrading the exhaust to a Banks system which includes a superscoop for the intake.......
Done this many years ago. Did you get the Stinger Kit? boost, egt gauges.
And there prom chip? The kit also came a K&N filter I have ran for the same time. Now I run the aFe filter.
,..... The other option was to use an AFE filter assembly, but it seems to me that since this assembly is basically an open filter in the engine copmpartment it would result in sucking hot engine air rather than cool outside air........
Lost me on that one not knowing what filter your looking into.
BNave95C3500
95C3500.Ext.Cab 97 Cooling mods. DSG Gear-1.95 TDCO. Bilstein Shocks. Firestone Air Bags. FSD Cooler. Banks EX System. Egt,Boost & IAT Gauges. JK High Flow/pop Injectors. Turbo-Master. Max-E 2.0. Water/Alky Injection. Amsoil Dual Bypass. Baldwin filter. aFe Air filter, Air box & Turbo Mods. Power Service Product. Large Duels 235/85-16. Tool Box\'s & truck, 8200 lbs.
Old 04-04-2006, 04:37 PM
KenDavis KenDavis is offline
Default Air intake upgrade
I recently replaced my stock air intake with the AFE Stage 2 intake system. Fit was good and easy to install. I also installed Jardine's Pinnacle Power Exhaust system, 4", from the turbo back. Power was definitely better and mileage went from 15.6 to 17.5 with just those two upgrades. I'm happy with the results.
1994 Chev Suburban 6.5L turbo, AFE Stage 2 air intake system,Triple guage, pillar mount, Jardine Pinnacle Power Exhaust, 4" system, 3" downpipe, '97 cooling mods, deep trans pan, remote FSD from Kennedy mounted on drivers firewall, Kennedy's mild chip (and what a difference it makes, wow), Kennedy's special fan clutch and new metal blades.
Old 04-04-2006, 05:09 PM
Craig M Craig M is offline
AFE appears nice, but pricey!
  #5
Old 04-05-2006, 03:33 AM
Bnave95's Avatar
Talking
Quote:
My cost was $87 shipped. A replacement Eng. because to much dirt got in the oil, Cost?
  #6
Old 04-05-2006, 10:52 AM
roclongrider roclongrider is offline
$87 shipped for the AFE is decent. Who di you get it from??
'94 2500 Ext Cab, 5 speed, 4X4, flood recovery project.
  #7
Old 04-05-2006, 04:33 PM
Bnave95's Avatar
www.heathdiesel.com
  #8
Old 04-05-2006, 05:32 PM
HH's Avatar
HH HH is offline
Going Mobile
I upgrade to the 97 & later box in my 1993. Everything fit fine. I bought all the pieces in a kit from Pennisular Engine.
1997 GMC Savana - 6.5 TD
1967 Jeepster - Stock
1986 Jeep CJ7 - Stock
  #9
Old 04-06-2006, 02:18 AM
Bnave95's Avatar
Quote:
What was the cost?
  #10
Old 04-06-2006, 03:44 PM
Prices I have seen for the AFE around $250 or so.
