The Gear Vendors gear splitting helps a little on hill climbing with heavy trailers. While you technically will have 8 gears, some of them will be so close to each other that they are useless. You will have a double overdrive (the 4L80E is already an overdrive transmission) with the Gear Vendors. If you like to go 75/85 mph on the open road then the lower rpm's with the double overdrive will be nice, but you will only get this speed with a bare truck, not towing any significant weight. You might be better off spending your dollars on power enhansements for the truck rather than the Gear Vendors.
