  #11
Old 08-02-2006, 10:08 PM
glivingstone glivingstone is offline
Quote:
Originally Posted by More Power
Always... begin troubleshooting an engine running problem by changing the fuel filter, then test the operation of the electric fuel lift pump....
Thanks everyone for your help to date.
The fuel filter has been changed and there appeared to be no problem with the lift pump when I bleed the air from the filter housing.
I will post the codes as soon as I can have them read.
Also the vehicle had a new Blue label IP fitted about 8 months ago before I puchased it, and they have remotely mounted the FSD to a piece of 3 mm steel plate near the AC compressor.
This vehicle was running fine prior to this problem occurring overnight and was returning 7.5 Kms per Litre on the highway.
Look forward to hearing from you guys again.
Greg
  #12
Old 08-03-2006, 06:07 AM
noelb's Avatar
noelb noelb is offline
Contributor
I don't like the sound of where and what your FSD is mounted on. Take a look at some of the Kits and heatsinks available and compare. You might want to wait for more appropriate advice but sometimes the stainless steel screws on the FSD loose contact. You might try removing the FSD from the sttel plate and carefully removing the caps off of the two T03 case transistors. Then very carefully loosen and tighten the 4 screws - Not too tight!(2 for each transistor.) Then use some heatsink compund or pad and remount.
After reading all about FSD relocation and another alternative unit, I still believe the FSD to be the way to go and the best place is on the side of the IP where the manufacturer intended it to go.
The problem is that most time the damage occurs after the engine is switched off when the heat builds up in the engine bay. Whilst the engine is running the fuel running through the IP keeps the FSD cool but after the engine stops the heat build up can cause damage. For this reason I can't see a benefit to the Repositioning of the FSD to a Heatsink in the Enginebay except for the ease of replacement when it too fails.
I haven't seen your installation, but I'm not sure I would put a steel plate in the same class as a heatsink.
For the vehicle to have been running fine when you switched it off tends to lead me to think the FSD is worth a thought!
Noel
1998 (Badge Re-engineered)RHD GM-Holden Chevrolet Suburban K2500, 150k miles, Turbo Diesel 583Nm 200Hp, New 4L80E, 3.73:1, Rebulit T/case with New Housing, standard 245's factory 6.5" wheels. No Mods. Car Code OBDII interface with Enhanced GM data, test & command modes, data logging, live data etc.
Toyota HZJ80 Landcruiser 4.2L Turbo Diesel, 195k miles, 430Nm 210Hp. Mitsubishi Water Cooled Turbo, Through bonnet Intercooler, Advanced timing and increased fuelling, 12 psi boost, Boost gauge and post Turbo pyrometer. 5 Spd Manual.
  #13
Old 08-03-2006, 11:15 AM
moondoggie moondoggie is offline
[font=times][size=+]Good Day!
[i]
95 6.5TD 2500 4X4 pickup, Gear Vendors Aux. OD, > million miles - gone
95 6.5TD 1500 4X4 3/4T Suburban, Kennedy exhaust, > million miles
  #14
Old 08-03-2006, 07:59 PM
Unhappy Help 6.5 TD Update
Hi everyone.
Well its not good news but I have managed to get some codes from a dealer although they have little or no knowlege of the vehicle and were hesitant to reveal the codes, here they are:
P0216 Injection Timing Control Circuit
P1214 Injection Pump Timing Offset
Does this in anyway point to the FSD or something else?
Also asked about checking the TDC Offset and the guy was clearly out of his depth.
Oh he also said that the Injection timing was 0.0 when in on mode and 6.8 when in off mode ???
Advice given was anything from a new IP to a new PCM (computer) they just don't know.
Vehicle appears to run fine for a minute or two when it is cold but then massively overfuels at low revs, however seems to run normally over 2000 RPM.
Any help would be appreciated.
  #15
Old 08-03-2006, 09:25 PM
noelb's Avatar
Contributor
Have a search of the forum for "P1214". There are some recent similar posts that may help. Would be a good Idea to get Actual readings before making any adjustments. eg Top Dead Centre Desired, Top Dead Centre Actual, and Top Dead Centre Offset. Remember to score a mark on the pump and timing cover so you can reverse any adjustments.
If you are technically minded you may want to purchase your own Scanner, I recently purchased a cable from the states to interface OBD II socket with a laptop. Didn't break the bank either!
Cheers
Noel
Noel
  #16
Old 08-03-2006, 10:42 PM
Cheers
Noel
Would love to have my own Tech II Scanner or similar that could check Injector pump timing and TDC Offset.
Can anyone suggest where to enquire and how much?
  #17
Old 08-04-2006, 02:21 AM
noelb's Avatar
Contributor
I did some research on several different ones and settled on Carcode. It interfaces the car to a laptop computer. Cost approx $200 AUD with a RS232 to USB adaptor, and software download. Can View Timing and TDC offset. Can Command TDC Offset learn and numerous other helpful things. (2-10 days delivery with Global Priority) got mine in about 9 days. It has Enhanced GM data and commands.
Noel
Noel
  #18
Old 08-06-2006, 11:16 PM
Noel
Thanks Noel, could you give me some more information on who to contact in relation to the Carcode.
Sounds like I will be able to set my own TDC Offset learn with this one.
Do you need to order software separatley?
