Go Back   TheDieselPage.com Forums > The Diesel Page Member Forums > 1982-2000 C/K Truck & SUV Chassis & Drivetrain
Old 08-19-2006, 06:57 PM
a5150nut's Avatar
a5150nut a5150nut is offline
Default Pitman arm removal
So what does it take besides removing the steering box to remove the pitman arm? Is there a tool that will fit between the bottom of the steering box and the cross member on a 4 X 4?
I called the dealer and they told me they don't sell any tools and for some reason my neighborhood Napa was closed today.
Old 08-19-2006, 07:53 PM
Rot Box's Avatar
Rot Box Rot Box is offline
95K25
I just changed mine about 2 weeks ago, and it wasn't fun My dealer said to use a pickle fork and an air hammer .........yeah right!
First loosen the box and large nut on the pitman arm, (don't remove the steering shaft) and point the pitman arm shaft towards the engine. Then buy a pitman arm puller from a parts store (its easy to identify the one that works the best. Their relatively short and have 2 ears with a large center bolt) Now for the fun part..... using a grinder or die grinder cut into the pitman arm towards the center splined shaft, but of course don't cut too far. Then when you have cut as much as you dare put the puller on it and it should come off. If yours has been changed recently then skip the grinder part, but if it was like mine you will just brake the puller (I broke 2 ) if you don't cut into the pitman arm. Good Luck! also look for the thread I posted about 2 weeks ago I't might help you some more
P.S. if you plan on keeping your truck then Anti-Sieze will be your best friend for re-assembly so it's not such a pain next time.
95 K2500 Silverado regcab, 6.5L F-vin, 4l80E, HD alloys 3" turbo back, Air intake, custom machined FSD isolator & I just turned over 50,000 original miles SOLD!!!
79 Toyota Hilux 20R, G52 5-speed swap, 4.7:1 t-case gear reduction, 4.37:1 R&P's, and 35" X-terrains. Too bad the poor thing is about to die from skin cancer
86 F250 Lariat 4x4 6.9 diesel, 4 speed, 3.55 gears, and lovin it
Old 08-19-2006, 08:10 PM
ronniejoe ronniejoe is offline
You need a better puller...
I didn't need to grind on mine and do not recommend grinding on anyone else's. A good puller will bring it right off.
Ron
1995 K2500 Suburban 8600 GVWR 6.5TD towing 32' 1999 Wilderness 31G GCVW 16,300+ lb.
KD 18:1 pistons with KD splayed mains. Read about it here: Part I, Part II, Part III.
Old 08-19-2006, 08:44 PM
Rot Box's Avatar
95K25
The first puller i broke was made in Taiwan so that probably had something to do with it, but the second one was good USA steel. I also had a large C-clamp wrapped around it to keep it from bending outwards. The threads started to strip right before the ear snapped off. I couldn't believe how much pressure was on it.
I agree that I shouldn't have suggested grinding on it.. that was a big mistake. I personally found that to be twenty times easier than putting a puller under that much stress not to mention the other tools involved. I will stand by this when I say that some are worse than others in my case it was OEM equiptment from 95 and I live in the rust belt. I figured the grinder idea was a lot better than some of the Ideas a couple "profesional alignment shops" suggested to me: Like torching it off, or the pickle fork air hammer idea or my favorite: "just use a punch and sledge hammer"
Bottom line: Use your best judgement and don't compromise safety.
  #5
Old 08-20-2006, 07:47 AM
a5150nut's Avatar
Smile
I had allready tried a pickle fork just to have the houseing give before the pitman arm. Thought about heat, but then there is a seal all too close. I just hoped there was an easyer method...........short of removing the box! Now where did I leave the Dynamite and blasting caps............? I know they are arround here somewhere.
  #6
Old 08-20-2006, 11:45 AM
Warren96 Warren96 is offline
Default Grind it off....
Thats how i did mine.Take your time, when you get near the end mine made a pop and the last 1/8th of an inch just cracked.If you cut the pitman twice you don't even have to loosen the steering box.No torches, no sledgehammers, just patience! Good luck and keep us posted!
  #7
Old 08-21-2006, 01:09 PM
JoeyD JoeyD is offline
Snap on has a nice puller. I just did mine as well and was not that bad. Remove the bolts holding the box on then twist it a little bit and put the puller in place then crank it off.
If you pitman arm is bad check your idler arm as it easy to do at the same time.
  #8
Old 03-16-2007, 03:27 PM
derekja derekja is offline
Hmm, how strange and scary!
I was expecting a major battle with the pitman arm. Instead it popped out of the relay arm without issue, then I carefully undid the steering box and rotated it to get access to the pitman arm, undid the bolt with little more than finger pressure, and then the pitman arm just kind of fell off while I was adjusting the gear puller.
Should I be worried about the steering box?
I guess I'll not look a gift horse in the mouth and will just replace the pitman and idler and torque them down to spec.
Wow.
1998 Chevy silverado 3500 4x4, 6.5TD, 215000 miles, 4L80-E, 4.10 ratio, 6" lift, gauges and intercooler... and a newly rebuilt engine on new block and heads!
  #9
Old 03-16-2007, 05:11 PM
Robyn's Avatar
Robyn Robyn is offline
Missy Good Wench ( Moderator)
If you are trying to get the arm off the steering box??
*** Be sure to remove the bolt from the thing and not just loosen it as the bolt goes through a groove in the shaft to keep it from falling off****
Dont be pounding on things or using heat!!
You can if you are careful TAP (LIGHTLY) a wedge into the split to relieve the tension on the splines and it should come off fairly easy.
A pickle fork can be used on the end oposite the gear box but again be careful not to slam the box.
These boxes are fairly tough but dont like being pounded on and do have some delicate parts inside that can be fouled up if you wail on them with a hammer.
The best puller is in order, as was mentioned thew Tiawan stuff will probably fold on you.
If this does not work for you and the arm is toast anyway the use of a cutoff wheel on a die grinder to relieve things at the back away from the split line is not a bad deal.
Better to do that than get rough with the box.
And for Gawds sake dont get a torch in there !!!!! bad news all the way around.
**OH BTW ** when you install the new one use never seaze on the splines after you clean them well with a wire brush to get all the crud and rust out.
Hope this helps
(1) 95 Suburban 2500 4x4
(1) 2017 Mercedes C class
(1) 1997 Astro "CATVAN II"
  #10
Old 03-16-2007, 10:02 PM
NH2112 NH2112 is offline
I've always known well in advance when I had to change one, and what worked well for me was to spray Aero-Kroil onto the arm & shaft every day before doing the job. Other good penetrating oils are Loosey-Goosey and PB B'laster. You know it's good, it says "As Seen On TV!" on the can!
The heavy-duty OTC Pitman arm puller works great. If it comes off very hard try tightening the heck out of the forcing screw then, using a small hammer (16oz), tap the side of the Pitman arm. Tighten the forcing screw some more and tap it again. Don't be afraid to pour the penetrating oil on, either!
Phil
