Are there any GM equivalent power steering fluids available besides getting from the stealer? What are the other brands for my 02 Duramax?
02 D/A CC Short Bed
Nothing really fancy about power steering fluid. Old timers use auto trans fluid. When I change mine I walk across the street to Napa where they carry Royal Purple synthetic fluid. Works good for me. Their gear oil is good as well.
David Proske #418
'06 CHEVY LBZ 2500HD CC LWB
'03 GMC 2500HD D/A *sold* :-(
'94 K2500HD W/GV OD
Been using Amsoil synthetic ATF (Universal) for over 100K. No problems. I've always used ATF, and will continue until someone has a valid reason not to. It is a simple hydraulic system, afterall.
Thanks for the replies. This is my first diesel and did not know if it required anythng special due the the brakes being powered by it as well.
02 D/A CC Short Bed
DmaxMaverick....
Are you serious on using Amsoil unuversal atf? Would it be alright to siphon the old out and replace as much as possible with it ?It would probably run cooler. My 05 seems to have quite a whine in the brake booster when I tow for a while and then let it sit for a few min. and then use the brakes hard.
Dad's truck
02 GMC Crewcab Dually Duramax Allison 4x4
Amsoil Ea Air Filter
Post OEM Mega Fuel Filter;
FilterMag on Fuel & Oil;
Fumoto Drain Valve
Kennedy Diesel Performance ECM
Gauges; Kennedy Diesel Lift Pump
Sheffenecker Mirrors
Sold
05 GMC Crewcab Shortbed Duramax Allison 4x4...
Dad's truck also (My daily driver)
2007 Classic Crew Cab 3500 Dually
Kennedy Diesel Mega post Fuel filter
Kennedy Diesel Lift pump & EGR blocker Package & fingers stick
Bilstein shocks
Amsoil synthetic oil and filters
FilterMag on fuel and oil
Fumoto drain valve
Amsoil Dealer
