Go Back   TheDieselPage.com Forums > The Diesel Page Member Forums > 1982-2000 C/K Truck & SUV Chassis & Drivetrain
Old 01-30-2007, 05:59 PM
xtrempickup's Avatar
xtrempickup xtrempickup is offline
Z71 Off Roading
Default 95 6.5L K2500 4x4 what kind of rear diff?
I was wondering what kind of rear diff is in my stock 95 6.5L 2500 Sierra 4x4 because I've been looking at the HD2500 trucks and they come with a posi rear. Not sure if mine is just a regular open diff or if its some sort of weak limited slip. can anybody tell me. what kind of options do i have for making it a posi rear? make just get the diff from a newer 2500 HP truck and make it work with the right gear ratio
95 GMC Sierra 2500 4x4 6.5L turbo ext cab 6ft bed ( relocated NEW PMD with cooler, running so far so good) SOLD SOLD SOLD
95 Chevy Silverado 1500 4x4 Z71 stepside 350V8
Old 01-31-2007, 04:18 AM
C.K. Piquup C.K. Piquup is offline
Do you have 6 or 8 lugs(14-bolt semi-floating)?There were light and heavy 2500s.If 8,does the rear hub stick out like a front hub on the old-style 4wds(14-bolt full-floating)?It cold be open or could be the Gov-Loc,as limited-slip/locking diff.
aka:Tim
`91 V2500 Scottsdale Suburban:6.2 4L80E 4"Lift 35s
`92 K3500 SLE SRW:Peninsular6.5TD Peninsular 5spd
`72 K20 CustomDeluxe Highlander CustomCamper
`72 K20 CheyenneSuper CustomCamper
`72 K2500 SierraGrande
`71 K10 CustomDeluxe 6' Fleetside
Old 01-31-2007, 05:08 AM
Z71 Off Roading
6 lugs, i'm guessing its the open diff and nothing sticking out
Old 01-31-2007, 08:18 AM
joed joed is online now
Default Look at your RPO codes...
Being a 6 lug, you have a semi-floater, but could still have a locker.
For the locker, the easiest way to tell is to look up your codes on the glovebox sticker. Look for a code "G80" - this indicates you have the factory locking differential. You can also tell gear ratio, GT4=3.73, GT5=4.10, GU6=3.42, etc.
Also, I'm not sure the newer HD trucks automatically come with a locker, just seems that most are equipped that way.
Hope that helps.
Joe.
  #5
Old 01-31-2007, 09:11 AM
Shikaroka Shikaroka is offline
The Todd
Huh.....
It's a 3/4 ton (2500), right? I thought 3/4 tons were 8 lug, and I thought all the diesel trucks were 8 lug. I guess I was wrong??
  #6
Old 01-31-2007, 10:39 AM
DmaxMaverick's Avatar
Administrator
Quote:
Originally Posted by Shikaroka
Huh.....
LD (Light Duty) is 7200# GVWR, and semi-floater 6 lug r/e. Also equipped with the same smog as the 1/2 tons in most states.
HD (Heavy Duty) is 8600# GVWR, and full floater 8 lug r/e.
However, I've seen factory LD's with 8 lug full floaters, too, with no rhyme or reason for it, and the same RPO's as the LD's.
2500 Suburbans were all 8600 GVWR.
  #7
Old 01-31-2007, 02:00 PM
Colorado Kid's Avatar
Colorado Kid Colorado Kid is offline
And just to cause further confustication 1500 Suburbans with 6.5 Diesel engines had 8 lug wheels and the semi-floater 9.25" 14-bolt.
2002 GMC Sierra 2500HD CC D/ZF SB Fire Red 2WD no longer the fastest stocker up the hill at the TDP Pull Off. -sold-
2004 Chevy Suburban 5.3L 2WD
1996 GMC Sierra 1500 5.0L 5sp 2WD LB
  #8
Old 01-31-2007, 02:31 PM
Z71 Off Roading
yea it is confusing as i thought all the 2500 and up trucks had 8 lug. when i got this is was very surprised, i just sold my gas with a 6 lug with new tires on AR wheels that I could have used. oh well, i'll check the glove box codes and see. I see GT4 which i guess means my gear ratio is 3.73. Rear is 14 bolt. Is that any good with the 305/70/17 in tires that I have on? No code for a limited slip, I guess might just be the standard crappy rear. Any idea what to look for if i go to a junkyard like in gas and diesel trucks to find a factory locker or posi rear? http://www.jegs.com/webapp/wcs/store...0002_750876_-1 found this Eaton LSD for 497$, looks like it should be the right one, do these trucks have 33 spline axles? Also is PowerTrax which is a locker type set up that fits and is about 470$?
  #9
Old 02-02-2007, 10:13 AM
The Todd
I should have known it was not so cut-and-dry.
