1) Replace the current injector pump--I have a DB-4911 core, so I'm thinking it'd make sense to replace the old pump (4275?) with the 4911, which was factory calibrated for the turbo (right?). Need to save this until right before I put in the turbo though, because it'll run high EGTs otherwise (even with the stinger exhaust system), right?
2) Replace the old worn injectors--but not with stock, maybe Kennedy hi pops? Or Peninsular marine injectors?
3) Replace the old glow plugs--with 11Gs? Or with Kennedy quick heats?
4) The truck has a factory trans cooler in front of the radiator, but I wonder if I should replace it with a larger one? With a dedicated electric fan?
5) No engine oil cooler, except in the radiator (factory stock), should I add an external oil cooler in front of the radiator? Also with it's own fan?
6) Maybe a higher performance Kennedy fan to replace the stock one?
7) Compression test before I sink big bucks into all the above parts. Oil pressure seems OK, and I'm not seeing oil smoke (or using much, maybe a quart every 3K miles), but what minimum compression should I be looking for before I start looking for a new motor/short block instead?
The final question is of course, what might I be missing here?
