Speed sensors @ wheel, rotors, drums, wheel bearings are almost always for ABS and Traction and Stability control systems. Speed sensors are located in transmissions, transfer cases and differentials. If water is a problem especially if sensor was replaced recently and appears to be in good condition I would suspect a wireing problem. Either a connector or wire insulation compromised such that moisture is causeing incorrect input signals to the system. bob............
Bob O.
2004 K2500 DA LLY CC LT LB Wow! Edge w/A + BS + CAT pre fuel filter, 06 air box,
2002 C6500 EC. 7.2 Cat NoMar rollback/ 92 C7500, 7.2 Cat, 25ton No-Mar / 2005 C5500 D/A rollback / 1969 Corvette 350-350 4spd AC T-top stock orginal
XP850LE WOW nice ATV, 09-550XP hers, 03-Predator, 04 Honda400EX, 05-Banshee, 08-KTM525, 08 KFX700, 38' enclosed GN hitch
