Thread: 6.5L Turbo Diesel - Crank Case Breather Elbow/Tube
    Aug 2007
    Sacramento, California
    Default 6.5L Turbo Diesel - Crank Case Breather Elbow/Tube
    On the 6.5 Turbo Diesel, does the Crank Case Breather Elbow/Tube (going from the Air Intake Turbo Elbow to the Crank Case Tube/Pipe) have to be the original GM Part, or does a regular 3/4" water hose suffice since there is only air going through there anyhow?
    Any advise?
    Thanks in advance.
    '96 Chevy Suburban LT 2500, 4x4, 6.5L Turbo Diesel, 4.10 Rear, 175K miles
    *** Towing 26' ft. Travel Trailer (6,165 lbs DRY) ***
    - aFe Stage 2 Performance Air Intake Kit
    - 4" inch Jerry Jardine, PINNACLE POWER EXHAUST, 5" inch Chrome Tip
    - 2-1/2" inch Crossover Pipe, mandrel bent
    - KENNEDY remote mounted PMD/FSD Cooler Package, DTech PMD
    - AUTOMETER Triple Gauge Pillar (Boost, EGT/Pyro, Trans. Temp.)
    - HEATH Turbo-Master
    - HEATH Max-E-Tork PCM
    - PRODIGY Brake Controller
    - BILSTEIN Shocks
    - Forged WELD RACING Rims
    - 265x75 R16 BF GOODRICH All-Terrain T/A's
    It's not just air going through there. The hose needs to be compatible with engine oil. Heater (water) hose works, but you'll have to replace it more often. Oil will soften it much quicker than the OEM hose. Heater hose doesn't make sharp bends well, either. They will usually kink once exposed to underhood temps.
    Jan 2006
    Boissevain, MB., Canada
    Unhappy crank case elbow/tube
    I had mine crack too, trouble is the tube reduces to 5/8" at the air intake hose, I made a temporary fix by using piece of washmachine hose and a 3/4" copper elbow and 1/2" reducer. I was worried that the hose would deteriorate and pieces would get into the turbo, so bit the 'Bullet' and got the GM hose , $28+ cdn, got hose and HOSED !!! Don't think it is available any where else. Oh well the cost of driving a Luxury vehicle lol!
    '95 GMC K2500, "Bullet"Ex. cab short.4X4, 377,000kl on truck, 177,000kl on AMG engine, auto. 3:73 Ltd. slip, FSD remote mount, OPS relay,AFE air IN, Kennedy 3 1/2" OUT . '83 F250 HD3/4 " Robert The Red Ford"4x4 460, 3:55'posi . 2005 GMC : G WHIZ" crew short box, 5.3, 4:10. , '88 Bronco II 4X4, '95 141,000kl Ford F150 EX. short box, '92 "Toy" 4 runner 273000kl ,'63 Mercury 45000miles !!!! Auto insurance co. is my mistress !!!
