Results 1 to 6 of 6
Thread: Caveat Emptor
    Mar 2007
    Default Caveat Emptor
    Well, I mentioned my bad experience with a set of aftermarket heads (which I will elaborate on). It turns out the vendor isn't any better quality than their products
    First, let's have some show and tell. Here's one of the aftermarket heads next to a somewhat rusty GM head:
    I threw them on a scale to see if there really is more metal in the aftermarket casting. First the GM head:
    Now the aftermarket casting:
    The aftermarket casting is 5lbs heavier than the GM head (I sat 4 precups on top of the GM head since it doesn't have any installed). However, a close examination reveals that all the extra mass is on the exterior of the casting. The deck is approximately the same thickness as the GM head, as are the internal passage walls.
    The valve job isn't too bad either:
    One intake seat is scratched, and would need to be touched with a seat stone to clean it up. You can alse see the induction hardening discoloration around the ports in that pic.
    (cont)
    Mar 2007
    I popped a set of valves in to check out the fit:
    The guides felt OK, and the seats appeared to be concentric with the guides. Not surprising since it is probably all done with one combination cutter. I should also note that the marks you see on the precup were caused by the brass rod I used to drive it in after I removed it. The material these cups are made of is very soft compared to the GM cups Here's a pic of the precup:
    If you put a magnet to a GM cup you will find the material is completely non-magnetic:
    The aftermarket cups, OTOH, were as magnetic as the cast iron heads:
    I have a fairly good knowledge of metallurgy, and off the top of my head I don't recall any alloys suitable for this type of high-temp service that are magnetic. There may be some that are weakly magnetic, but I don't recall any. This says to me that these cups are, at best, a ferritic or martensic stainless. Not the best material for a part that runs at a sustained 1000+ degrees in an environment that alternates between oxidizing and carburizing while being subjected to steep pressure spikes. Maybe I am wrong, but I am not going to test them in MY engine.
    (cont)
    Mar 2007
    It gets worse. I had a machinist friend check out the fit of the cups and their bores in the heads. When I removed the one cup I found metal shavings on the seat that the cups bottom against. After measuring the diameter of the aftermarket cup, the GM cup, and the bore, he found that the aftermarket cup was .002" too big. It also had no chamfer on the seat side like the GM cup has. Apparently, when driven in the cups (even as soft as they are, they are harder than the cast iron) broach material off the substantially smaller bore. This material has nowhere to go, so it gets trapped under the cup's seat. Once I removed the cup and wiped away the shavings I could no longer get the cup to sit flush and level. The head was surfaced with the cup sitting in the bore at a slight angle atop some shavings, and this showed up when I measured the cup's seat at 4 points:
    Yup, one side is .022" higher than the other. The bores have an even depth all the way around (within a thou or two), so in order for this head to be servicable it would need at least one or more new precups (depending on how many are like this one) and then resurfaced. Figure $200 just to make this one head useable I'm sure the other head isn't any better...
    Now to add injury to insult: I ordered these heads from Clearwater Cylinder head after reading the favorable things folks here and elsewhere had to say about them. Well, they basically said "What do you expect for that kind of money?". They agreed to take them back, but I would have to pay to ship them back ($75, minimum), lose the freight I paid to have them shipped to me, AND I would have to pay a 20% restocking fee. All told I would be out $225. Judging by their attitude I have no doubt they would refuse to take back the head with the now-ill-fitting precup in it, so basically I am SOL. I didn't expect AMG heads, but I DID expect the machining and assembly to be basically correct and the heads to be serviceable without worrying that an ill-fitting precup will shift on it's seat of debris and cause the loss of a $120 Cometic head gasket. I didn't want to worry that a precup of possibly inferior mettalurgy may crack apart and drop into the cylinder during operation, which is what occasionally happens with the Toyota 4-cyl IDI's.
    Anyway, there you have it. I am now the proud owner of a pair of cast iron doorstops. The worst part is that I KNEW BETTER!!! I should have went with what experience has taught me, despite the good reviews from well-meaning individuals. I have seen too much garbage like these heads to have any faith in these Chinese replacement parts.
    Folks, if you have cracked heads, Lock'n'stitch works. Have a pair of seats put in, surface the head, do a valve job, and keep running your GM heads. You will be better off in the long run. If you really want new heads, pony up the $1000 for a pair of fully assembled AMG heads. Yes, it is twice what I paid for these bare Chinese castings, but it is only $350 more than the Chinese heads assembled with reconditioned parts, and you get all new stuff. The only reason I didn't go that route is because I already have new valves and springs which are higher quality than the OEM AMG stuff, so I wanted a bare head, AMG doesn't sell them bare, which is why I decided to try this route. I got burned, and now I will be repairing the small crack in my GM heads and using them anyway. $550 is an expensive lesson...
    Lubbock TX, USA
    Well Done!
    Thanks for this excellent contribution to the forum! I followed everything you had said and it all makes perfect sence. I had also heard that aftermarket companies were selling replacement Diamond precups, but they were very inexpensive. Once used in GM heads, they would protrude .002" out of the hole, on a set of heads that had proper depth for a precup (tools are available to reset). So to use them would mean increasing the depth of the precup hole to accept the aftermarket (and probably inferior) precup.
    I really like how you group the heads side-by-side, you can plainly see differences externally on the heads on BOTH the intake side and the exhaust side.
    I'm also disappointed that they are being difficult with the return.
    Back a few years ago I purchased as set of heads from Alabama Cylinder heads. I was advised by Benny Avant (Diesel Depot) that the heads were inferior and that if I could that it would be best to send them back. Alabama Cylinder Heads did take the heads back, with a no-questions asked attitude, even paid the shipping back to them, and refunded the entire costs that I spent on them. I didn't even get to argue, I was out absolutly nothing.
    So, it seems that you've found out that the Clearwater heads are no better than the Alabama Cylinder heads. There are differences between the two, I think there are three variants of these aftermarket heads in circulation.
    1986 C10 SCLWB 6.2TD 3.73 700
    1989 V20 SUB 6.2NA, 3.73 400
    1994 G20 VAN 6.5NA, 3.42 60E
    1996 K30 DRW 6.5TD 4.10 80E
    Mar 2007
    Quote Originally Posted by john8662 View Post
    Well Done!
    At this point I wouldn't trust any of them. At least ACH took your stuff back. I don't know if their heads are any good or not, but it sounds as though their customer service is excellent. Too bad I didn't order my junk from them
    I talked to Clearwater this morning and inquired about the 6.5 heads.
    I posted the results of this conversation on the thread in this forum (Aftermarket heads)
    Robyn
