Just a story. I know of a Duramax in an 07 C5500 chassis, 1 of 9 the company bought, that spent 3 of its first 4 months in the shop. Replaced all kinds of parts, wireing harness, injectors , hp pump, sensors, etc. for many different symptoms, all under warranty. Most anyone who works on electrical will tell you to check the backside of the circuit or ground side,,,, problem was the body up-fitter failed to reattach a ground wire in a hard to find location. GM is supposed to have back-charged the body company for upwards of $8000.00! this is the word I was told, do not know if GM can back-charge an authorized up-fitter or not. May or may not be a problem but a wireing diagram and all grounds found and checked on a vehicle with lots of issues is time well spent.
Check for ground connection integrity and that all are attached.
And what Duramaster said!!!
bob..................
Bob O.
2004 K2500 DA LLY CC LT LB Wow! Edge w/A + BS + CAT pre fuel filter, 06 air box,
2002 C6500 EC. 7.2 Cat NoMar rollback/ 92 C7500, 7.2 Cat, 25ton No-Mar / 2005 C5500 D/A rollback / 1969 Corvette 350-350 4spd AC T-top stock orginal
XP850LE WOW nice ATV, 09-550XP hers, 03-Predator, 04 Honda400EX, 05-Banshee, 08-KTM525, 08 KFX700, 38' enclosed GN hitch
