2013 - TDP's 18th Year
Duramax 6600 Diesel Page | Advertiser's Section | Classified Ads | Photo Album | Diesel Books, GM Licensed Ball Caps & T-shirts
Duramax 6600 Discussion Forum for the Duramax 6600 Diesel Engine, including the LB7, LLY, LBZ & LMM engine specific topics.
Old 10-27-2008, 04:27 PM
f.forney f.forney is offline
poormanz
Default how do i replace injectors on 6.6 2004 lly
Am I in over my head? Looking for a manual online, and lots of tips.
Just got the replacements in the mail and ready to move fwd.
Only going to replace #6 & #7(dont even know the postions of them yet).
The diagnostic showed #7 failed and #6 Partially failed. Also could build no full rail pressure, only 154MPA.
Any tips diagrams would be helpful
Thanks,
F
yes I am new here!
Old 10-27-2008, 06:25 PM
Administrator
Welcome aboard!
www.alldatadiy.com
You won't do any better than that, online or in print. Unless, of course, you insist on a paper/ink solution.
The banks are opposite that of previous GM V-8 engines. 2-4-6-8 is on the left/driver side, 1-3-5-7 is on the right/passenger side. 1 and 2 are the front cylinders.
1985 Blazer 6.2 (over ½ million miles)
1995 C2500HD 6.5 (so far, so good)
Old 10-28-2008, 08:04 AM
Duramaster's Avatar
GMC World Class Technician
154 MPA is more than plenty to run. The Number 7 is the right rear injector (Passenger side). The Number 6 is the third one back on the driver side. The high pressure lines are torqued to 30 ft lbs. The injector hold down bolts are torqued to 22 ft lbs. You will need 12 mm socket for the injectors, 17mm wrench for the injector lines. Possibly a T-30 torx for the engine harness. Basically you need your typical Japanese engine tools ........... 10, 12, 14, 17, 19 mm. Good luck.
Old 10-28-2008, 09:00 PM
poormanz
Default thanks for the info, was
wondering, are the injectors on the block or under the valvecovers like my cummins.
  #5
Old 10-28-2008, 10:23 PM
Duramaster's Avatar
They are outside of the rocker covers aticking through the center of the head.
  #6
Old 10-30-2008, 08:22 PM
poormanz
Default So far so good...
Replaced #7 injector this evening and no more knocking noises from the valve...just let me run this by you, #7 had -7 ballance and #6 had +4 ballance.
Before I replace #6 is it necessary to replace #6 (is +4 ballance good or bad)? And any other tips on the 2 4 6 8 side?
The lly seemed very easy so far and thanks for your previous tips!
  #7
Old 10-31-2008, 12:40 PM
Duramaster's Avatar
Balance rates should be 0 mm +/- 4.5 in P/N and 0 +/- 6.5 in gear.
  #8
Old 10-31-2008, 05:59 PM
poormanz
Default thanks for the info again, broke the plastic T
for the fuel line that daisy chains between the injectors. This T connects to the top of the injector where the wires connect. Must be a dealer item?...cause none of the parts stores have it, right?
  #9
Old 10-31-2008, 06:18 PM
Duramaster's Avatar
That's correct. It comes as a complete hose/ fitting assembly. You need to specify right or left bank.
  #10
Old 10-31-2008, 06:23 PM
poormanz
Default Right, gotta sell me the whole left bank...
for a fitting?...How nice, pretty costly?
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 1996-2011 by TheDieselPage.com - All Rights Reserved
