Old 07-30-2009, 07:52 PM
sgoodhope sgoodhope is offline
Newbie
Default Need to know the best way to remove the oil pan?
Hello, new guy here, I need to know the best way to remove the oil pan. Is it buy taking the motor out? Or dropping the front end? Let me know. You can contact me at sgoodhope@hotmail.com
Old 07-31-2009, 09:40 AM
More Power's Avatar
Administrator
The stamped-steel pan comes off pretty easily, but the aluminum crankcase is a bit more work - in the truck. If you expect to do more work (i.e. remove connecting rods, oil pump etc.), removing the engine might be a better option.
Old 07-31-2009, 07:38 PM
Newbie
Default One big headach
Hello again, I now have the trans pulled away from the block. Just getting ready to go and drop the 2 bolts holding the upper pan in place. I guess I will just have to figure it out along the way. Replys are slow and not very forth coming. One thing that would be nice to know is what is the torque spec on the piston rod bolts. I will post again after the job is done to let everyone know how it went.
Old 07-31-2009, 09:40 PM
Duramaster's Avatar
GMC World Class Technician
What are you doing? Inspecting or replacing? Bearings usually aren't a problem on the DMAX engine. I personally have seen LB7 engines go 300K.
Anyway, torque specs for the LB7 is::
Well........... sorry, I just tried to look up the specs on the GM SI website. The website is currently down? I will try again later for you.
  #5
Old 07-31-2009, 10:30 PM
Newbie
Default Bad injector leads to # 3 cylinder melt down
My injectors started to go. I took it to GM. They ran there diagnostics and found that the right bank was running a return rate of 61ml and the left was 42ml. They replaced the injectors and buttoned it back up. When running the truck for the first time they noticed a miss. Pulled the glow plugs and did a compression test. All cylinders were at 390f/lb except # 3. It was dead. They called me up and said do you have 5000.00 so we can fix your truck? I said I will do it myself. Right now I just have a fuel line to remove and a few motor mount bolts and the motor will be out of the truck by noon. I already took the head off and it has been repaired with a new valve seat and valve pluse a 2thou decking to make sure it seats on the head gasket the first time. Now I have to pull the piston and replace it. It is toast. Luckly there was little to no damage to the cylinder it self a light hone should do the trick. Once I have it back together I will run a compression test on it before I install the glow plugs to make sure I have good pressure on # 3.
  #6
Old 08-01-2009, 12:39 PM
Duramaster's Avatar
Well then you need LOTS OF TORQUE SPECS! If you are going to mount the engine to a stand, you need to remove the rear aluminum flywheel housing.
QUOTE FROM GM SI::::::::::::::::
Caution: Do not mount the engine to a engine stand by the flywheel housing. The aluminum flywheel housing is not designed to support the weight of the engine when mounted to a typical rear-mount engine stand. Mounting the engine stand to the aluminum flywheel housing may result in engine damage and serious personal injury.
Fastener Tightening Specifications
Application
Specification
Metric
English
A/C Compressor Bolt
50 Nm
37 lb ft
Air Cleaner Outlet Duct Clamp
8 Nm
71 lb in
Air Conditioning Compressor/Power Steering Pump Bracket Bolt
46 Nm
34 lb ft
Battery Cable Bracket Bolt
12 Nm
106 lb in
Battery Cable Bracket Nut
8 Nm
71 lb in
Bypass Pipe Bolt
21 Nm
15 lb ft
Camshaft Gear Bolt
234 Nm
173 lb ft
Camshaft Position Sensor Bolt
10 Nm
89 lb in
Camshaft Position Sensor Exciter Ring Bolt
9 Nm
80 lb in
Camshaft Thrust Plate Bolt
22 Nm
16 lb ft
Charged Air Cooler Bolt
21 Nm
15 lb ft
Charged Air Cooler Clamp
8 Nm
71 lb in
Connecting Rod Cap Bolt - Angular Tightening Method
1st Step 64 Nm
1st Step 47 lb ft
2nd Step 30 degrees
2nd Step 30 degrees
3rd Step 30 degrees
3rd Step 30 degrees
Coolant Pipe to Water Pump Nut
25 Nm
18 lb ft
Cooling Fan Pulley
41 Nm
30 lb ft
Crankshaft Balancer Bolt
1st Step 100 Nm
1st Step 74 lb ft
2nd Step 105 degrees
Crankshaft Bearing Cap Bolt - Angular Tightening Method
1st Step 98 Nm
1st Step 72 lb ft
2nd Step 132 Nm
2nd Step 97 lb ft
3rd Step 30 degrees
3rd Step 30 degrees
Crankshaft Bearing Cap Side Bolt
78 Nm
58 lb ft
Crankshaft Position Sensor Bolt
10 Nm
89 lb in
Crankshaft Position Sensor Spacer Bolt
10 Nm
89 lb in
Crossmember Bolt
100 Nm
74 lb ft
Cylinder Head M12 Bolt - Angular Tightening Method
1st Step 50 Nm
1st Step 37 lb ft
2nd Step 80 Nm
2nd Step 59 lb ft
3rd Step 60 degrees
4th Step 60 degrees
Cylinder Head M8 Bolt
25 Nm
18 lb ft
Drive Belt Tensioner Pulley Bolt
41 Nm
30 lb ft
EGR Bolt - California Emissions
20 Nm
15 lb ft
EGR Bracket Bolt - California Emissions
20 Nm
15 lb ft
EGR Valve Nut - California Emissions
19 Nm
14 lb ft
Engine Block Coolant Plug
18 Nm
13 lb ft
Engine Block Ground Bolt
34 Nm
25 lb ft
Engine Mount Through Bolt to Frame
75 Nm
55 lb ft
Engine Mount to Block Bolts
58 Nm
43 lb ft
Engine Mount to Frame Bolt
65 Nm
48 lb ft
Engine Shield Bolt
20 Nm
15 lb ft
Exhaust Heat Shield Nut
9 Nm
80 lb in
Exhaust Manifold Bolt/Nut
38 Nm
28 lb ft
Exhaust Manifold Heat Shield Bolts
8 Nm
71 lb in
Exhaust Outlet Clamp
15 Nm
11 lb ft
Exhaust Outlet Heat Shield Bolts
8 Nm
71 lb in
Exhaust Outlet Pipe Bolt
53 Nm
39 lb ft
Exhaust Pipe Bolt
53 Nm
39 lb ft
Exhaust Pipe Bracket Bolt
34 Nm
25 lb ft
Exhaust Pipe Clamp
40 Nm
30 lb ft
Exhaust Pipe Heat Shield Bolts
8 Nm
71 lb in
Fan Pulley Bracket Bolt
46 Nm
34 lb ft
Flywheel Bolt - Angular Tightening Method
1st Step 79 Nm
1st Step 58 lb ft
2nd Step 60 degrees
2nd Step 60 degrees
3rd Step 60 degrees
3rd Step 60 degrees
Flywheel Housing Bolt - Black Circle Mark
80 Nm
60 lb ft
Flywheel Housing to Upper Oil Pan Bolt - Black Triangle Mark
50 Nm
37 lb ft
Front Engine Cover Bolt
21 Nm
15 lb ft
Fuel Block Bolt
25 Nm
18 lb ft
Fuel Filter Bracket Bolt
21 Nm
15 lb ft
Fuel Injection Control Module Bolt
20 Nm
15 lb ft
Fuel Injection Control Module Bracket Bolt
21 Nm
15 lb ft
Fuel Injection Control Module Connector Bolt
10 Nm
89 lb in
Fuel Injection Control Module Connector Bracket Bolt
21 Nm
15 lb ft
Fuel Injection Control Module Cooler Eye Bolt
27 Nm
20 lb ft
Fuel Injection Pipe Nut
41 Nm
30 lb ft
Fuel Inlet Pipe Bracket Bolt
21 Nm
15 lb ft
Fuel Pipes Bracket Bolt
25 Nm
18 lb ft
Fuel Rail Assembly Bolt
25 Nm
18 lb ft
Fuel Rail Connector
45 Nm
33 lb ft
Fuel Return Pipe Eye Bolt - Cylinder Head Side
17 Nm
12 lb ft
Fuel Return Pipe Eye Bolt - Injector Side
16 Nm
12 lb ft
Fuel Return Pipe Sleeve Nut
41 Nm
30 lb ft
Fuel Return Sleeve Unit
41 Nm
30 lb ft
Fuel Injection Pump Assembly to Cylinder Block Bolt
21 Nm
15 lb ft
Fuel Injection Pump to Bracket Bolt
21 Nm
15 lb ft
Fuel Injection Pump Drive Gear Nut
70 Nm
52 lb ft
Fuel Line Bracket Nut
21 Nm
15 lb ft
Fuel Temperature Sensor Eye Bolt
15 Nm
11 lb ft
Function Block Nut
25 Nm
18 lb ft
Function Block to Injection Pipe Nut
41 Nm
30 lb ft
Generator Bracket Bolt
50 Nm
37 lb ft
Generator Positive Cable Nut
9 Nm
80 lb in
Glow Plug
18 Nm
13 lb ft
Glow Plug Connector Nut
2 Nm
18 lb in
Glow Plug Power Feed Nut
15 Nm
11 lb ft
Glow Plug Relay Assembly Bolt
25 Nm
18 lb ft
Heater Outlet Pipe/Nose Bolt
25 Nm
18 lb ft
Heater Outlet Pipe/Hose Nut
9 Nm
80 lb in
Heater Pipe Bolt
21 Nm
15 lb ft
Hood Hinge Bolt
25 Nm
18 lb ft
Idle Pulley Bolt/Screw
37 Nm
27 lb ft
Injector Bracket Bolt
50 Nm
37 lb ft
Injector Harness Bracket Bolt
9 Nm
80 lb in
Injector Terminal Nut
2 Nm
18 lb in
Injector Pipe Lock Plate Screws
4 Nm
35 lb in
Intake Air Heater
50 Nm
37 lb ft
Intake Air Heater Terminal Nut
4 Nm
35 lb in
Intake Manifold Bolts/Nuts
21 Nm
15 lb ft
Intake Manifold Tube Bolts/Nuts
9 Nm
80 lb in
Oil Cooler Adapter Bolts
21 Nm
15 lb ft
Oil Cooler Adapter Nuts
25 Nm
18 lb ft
Oil Cooler Assembly Bolts
25 Nm
18 lb ft
Oil Cooler Adapter Stud
10 Nm
89 lb in
Oil Drain Plug
84 Nm
62 lb ft
Oil Fill Tube Bolt
21 Nm
15 lb ft
Oil Filter
24 Nm
18 lb ft
Oil Gallery Plugs
53 Nm
39 lb ft
Oil Level Indicator Tube Bolt
21 Nm
15 lb ft
Oil Level Sensor Bolt
10 Nm
89 lb in
Oil Pan Bolts/Nuts - Lower
10 Nm
89 lb in
Oil Pan Bolt - Upper
20 Nm
15 lb ft
Oil Pan Skid Plate Bolt
20 Nm
15 lb ft
Oil Pressure Sensor Unit
30 Nm
22 lb ft
Oil Pressure Relief Valve
39 Nm
29 lb ft
Oil Pump Bolt
21 Nm
15 lb ft
Oil Pump Driven Gear Nut
100 Nm
74 lb ft
Oil Pump Gear Cover Bolt
21 Nm
15 lb ft
Oil Strainer Bolts/Nuts
25 Nm
18 lb ft
Piston Cooling Nozzle Eye Bolt
21 Nm
15 lb ft
Positive Cable Junction Block Bracket to Power Steering Pump Bolt
9 Nm
80 lb in
Positive Crankcase Ventilation Cover Screws
4 Nm
35 lb in
Positive Crankcase Ventilation Oil Separator Bracket Nut
25 Nm
18 lb ft
50 Nm
37 lb ft
50 Nm
37 lb ft
46 Nm
34 lb ft
Rocker Arm Shaft Bracket Bolt
41 Nm
30 lb ft
Starter Motor Bolt
78 Nm
58 lb ft
Transmission Fill Tube Nut
18 Nm
13 lb ft
Thermostat Housing Bolts/Nuts
25 Nm
18 lb ft
Thermostat Cover Bolt
21 Nm
15 lb ft
Torque Converter Bolt
60 Nm
44 lb ft
Transmission Oil Cooler Clip Nut
9 Nm
80 lb in
Turbocharger Bolt
108 Nm
80 lb ft
Turbocharger Boost Sensor Bolt
10 Nm
89 lb in
Turbocharger Coolant Outlet Pipe Bracket Bolts
21 Nm
15 lb ft
Turbocharger Heat Shield Bolts
9 Nm
80 lb in
Turbocharger Inlet Duct to Turbocharger Bolt
9 Nm
80 lb in
Turbocharger Oil Return Pipe Stud
10 Nm
89 lb in
Turbocharger Oil Supply Hose Eye Bolt
34 Nm
25 lb ft
Turbocharger Oil Return Pipe Bolts/Nuts
21 Nm
15 lb ft
Turbocharger Thermostatic Coolant Valve
60 Nm
44 lb ft
Upper Oil Pan to Flywheel Housing Screws
20 Nm
15 lb ft
Vacuum Pump Nuts - California Emissions
22 Nm
16 lb ft
Valve Adjusting Screw Nut
22 Nm
16 lb ft
Valve Lifter Holdown Bracket Bolt
11 Nm
97 lb in
Valve Rocker Arm Cover Bolt - Lower
10 Nm
89 lb in
Valve Rocker Arm Cover Bolt - Upper
8 Nm (Two Times)
71 lb in (Two Times)
Water Outlet Bolts
25 Nm
18 lb ft
Water Pump Bolt
21 Nm
15 lb ft
  #7
Old 08-01-2009, 12:42 PM
Duramaster's Avatar
There are also three different thicknesses of head gasket plus a right and a left. You will need to check the piston protrusion of the new piston/ bearing assy before assy. Check your e-mail for the procedure. Remember to use new head bolts, rod bolts, crankshaft bearing cap bolts too................. You might try and get yourself a good manual for reference. This isn't your everyday 6.5 diesel!
