Our 95 Sub is acting up.
Here's the history of the current problem.
A 3 weeks ago the Sub shut off while my wife was driving. Happened before and was the PMD, so I put on the spare DTech and nothing - no start. Had it towed home and did a search on the diesel page. Checked fuses and low and behold the ECM-B fuse was blown. One thread on the search stated that the ECM-B fuse problem on his truck was fixed by moving the grounds at the rear pass side on the intake manifold to the next stud up. Checked the grounds and found 4 on the rear stud (1 braid that went to the frame, 1 short set of 2 wires into one lug, 1 heavy gauge maybe 10 or 12g, and 1 light gauge maybe 16g). I moved the heavy and light gauge grounds since they had enough wire for them to be moved easily. I left the braid and the 2 into 1 on the rear stud, but I cleaned and inspected them. Looked fine. The 2 wires I moved, were bolted to the upper intake manifold since it was convenient. Plugged in a new fuse and the beast cranked. This worked worked for about 2 weeks.
Then the Sub died again. ECM-B blown again. Had it towed home again. Since my last fix had to do with the grounds, I returnedt to them. While checking them again, I managed to break off a few lugs and had to solder on some wire and lugs. Moved the 2 wires I had previously moved to 2 different locations around the intake manifold. Kept blowing fuses when cranking - GP light for less than a second and then fuse blown. Another search and found a thread where a 97 was blowing the ECM-B fuse. It was suggested to check the items on that circuit - OPS, lift pump. OK - so figure if you unplug an item and then try cranking and if the fuse doesn't blow, then there is an issue with that item. As you can tell I am not electrical.
Anyway, I removed the fuel lift pump relay and cranked. No start - fuse blown,as usual. So when I went to put in a new fuse - it blew immediately!! Before that was not a problem - it would only blow when cranked. So apparently I screwed something up when cranking without the lift pump relay in.
Something is shorting somewhere, I guess.
Any thoughts? Anyone near Athens GA that would like to tackle this? Should I disconnect the batteries?
