Old 10-29-2009, 07:28 PM
john8662's Avatar
john8662 john8662 is offline
modeRATOR
Default Aftermarket 6.5 Diesel Heads, non china, source?
Going through my stash of cylinder heads but it's starting to look a little grim trying to find something my very picky machinist (but I like that actually) will work with.
So, I wanted to see about some Aftermarket castings that were NOT made in china. I had read somewhere that some were being made in Canada, but that might of just been an aftermarket block.
Please don't post about Clearwater, Alabama Cylinder Heads, or other that just sells the chinese stuff. Yes, Robyn, don't need no cheer leading for Clearwater in this thread.
Anyone know?
On the verge of also just ponying up and getting the AMG ones. I just hate to because the engine I'm trying to put together isn't a new (or bored and built) it's just a "Freshen up" and get the darn truck out the driveway deal. Gotta get the K3500 CC Dually running, need something that can haul the heavy things.
I've also considered the numerious companies out there that reman these heads in masses. I've contacted a few, but I didn't like the results as they all didn't perform the correct machine work on the heads. No use in buying a set of reman heads only to have to take them down to my local speed shop and have them made right (they also grumble about stuff like that too, fixing others' crap).
Thanks!
1986 C10 SCLWB 6.2TD 3.73 700
1989 V20 SUB 6.2NA, 3.73 400
1994 G20 VAN 6.5NA, 3.42 60E
1996 K30 DRW 6.5TD 4.10 80E
Old 10-29-2009, 08:55 PM
rogers's Avatar
rogers rogers is offline
Where there's smoke.... There's fire!
You might look at SSDiesel for some heads. I bought some from him last summer. He swore they were made in the USA, Alabama I think. I can't say for the quality as I haven't taken them out of the boxes yet. Just had other priorities. They look good sitting in the box though.
1996 GMC K3500 Crew Cab Dually 8ft bed
Rebuilt engine 2/10 18:1 pistons, forged crank, Fluidamper, dsg gear drive timing, high flow oil pump, rebuilt GM8, turbomaster, Kennedy ECM, 4" exhaust, wrapped cross-over and down pipe, '98+ cooling, Duramax fan, aftermarket oil cooler and hoses
Rebuilt tranny 2/10
Old 10-29-2009, 10:22 PM
john8662's Avatar
modeRATOR
ACH's heads country of origin is unknown, but I highly suspect China, as I've had a set of their heads. The heads are assembled here in the states using used valves and components. That's why they WANT the core back regardless of the condition of the casting.
When they first got in the game I saw a set on eBay pretty cheap, so I bought them. They had a no haggle return if I wasn't satisfied.
Well, I didn't like the machining on the surface of the heads, and the fact the precombustion ports were machined in the heads (with the surface grinder). They're not even stainless steel precups, who knows what they are. Probably that same pot metal crap that was used to make the GM heater quick connect fittings that breaks on every engine...
Anyways, I sent them back.
Now, there are about 10 different head shops selling different (or the same) reproduction heads.
The sales pitch is always the same too, "we increased the thickness in all the areas that crack to make them stronger." Ha, ha, ha! When you make the surfaces thicker that crack it can make the problem worse. From what I understand most cracking is due to uneven heat transfer, among other things.
They supposedly increased the thickness of the walls on the port that goes between the valves. Can't say this is the right move or not, but I suspect not. The crack always starts on the edge of the seat, exhaust valve primarily. So the cooling port being smaller isn't going to make any real difference, except that it'll take the crack longer until it get's to water. The crack will probably still occur. The real issue is the induction hardening on the seats, the crack starts here.
Rant off...
Still looking for Canada castings.
Old 10-29-2009, 10:46 PM
rogers's Avatar
Quote:
I'm sorry, who is ACH? SS doesn't ask for your heads. I am not trying to support SS, just trying clarify.
Rebuilt tranny 2/10
  #5
Old 10-30-2009, 06:35 AM
john8662's Avatar
modeRATOR
Quote:
You mentioned he got them from Alabama, I read into that as being he probably gets them from Alabama Cylinder Heads (ACH).
J
  #6
Old 11-15-2009, 12:37 AM
97-6.5TD-F's Avatar
97-6.5TD-F 97-6.5TD-F is offline
http://www.dieselservices.com/html/g...mplete_p92.cfm
I put a pair of these on my rebuild a few years ago, they appeared to be good quality but am not sure where they are actually cast. I put 40k on them towing and had no issues. I sold the truck though but am sure they are doing fine.
Joshua R. L. Certified Journeyman Automotive Service Technician
1997 K1500 6.5T, DSG gears 'n' girdles 364k
1997 K2500 5.7, 428k
1999 K2500 6.5T, 514K
1961 Apache 10 SWB panel, work in progress
  #7
Old 03-30-2010, 06:43 AM
mkhagemann mkhagemann is offline
John, did you ever get an answer to your question? The pair of heads I got from ACH weren't too great, one had alot of core shift. Unfortunately they needed to go back on one of my service trucks, now after 10k miles I water in the cylinder. To me it doesn't matter about warrantee, its the down time. Are there any heads that are not made in China?
  #8
Old 03-30-2010, 07:13 AM
john8662's Avatar
modeRATOR
I've decided that none other than new AMG castings will do. I ended up finding some heads in my collection that could be used.
Next set will just be new AMG heads.
Sorry to hear of bad heads on your engine, that's been my fear, and you're not the only one.
  #9
Old 03-30-2010, 07:39 PM
Bobbie Martin's Avatar
Bobbie Martin Bobbie Martin is offline
DB2 Conversion Advocate
That is what I bought for the engine I'm building. Paid about $900 for the pair. Genuine AMG with non magnetic diamond precups.
Bobbie Martin
1995 Chevrolet Suburban 1500 6.5 TD 2WD- DB2 mechanical fuel injection
GEP Optimizer 6.53 Detroit Diesel Power
6.53L, GEP Block & Heads, .020 over, ARP studs, DB2 Inj. pump, GM8 Turbo w/TurboMaster
K47 Airbox with K&N filter, 3" mandrel bent exhaust, 2¼" Crossover, Mann ProVent
HO Water Pump, Hayden "Truck Fan" Clutch, 21" 9 blade Duramax Fan
No PMD, APP, CDR, optical sensor or vacuum pump!
Author of The DB2 Conversion Guide
Click Here to Email Me
  #10
Old 03-30-2010, 08:03 PM
turbonator's Avatar
turbonator turbonator is offline
hey john, try 6.5liter.com, this guy gets his blocks from brazil, and i think his heads come from canada, also my brother jim just said he gets one of his blocks from canada as well... jim talked to him on the phone one time, over there they love the 6.5l...
you might know this guy better than us......
1993 sierra 3500 drw, 6.5L DB2831 ground spring, 4000rpm, custom cold air intake, H1C, 3 inch magna flow stainless muffler, remote tranny & engine oil coolers with fans.
