Thread: What's Causing My Backfire?
    Default What's Causing My Backfire?
    1986 Chevy G30, 200k miles. After a recent 200-mile highway drive, engine backfires and puts black smoke out the exhaust. Suspected head gasket failure between #5 and #7 cylinder, but replaced HG and problem persists.
    Low compression in #7 cylinder, half-burned fuel shot back up #7 intake runner. Valves are fully seated; springs, pushrods and rockers passed visual inspection.
    Ideas? Thanks in advance,
    -joe & christy
    Lubbock TX, USA
    Highly suspect valve issue here with the low compression and the popping in the intake runner.
    Inspect the entire tract of that cylinder's intake intake and exhaust valve:
    Valve, spring and damper spring, pushrod (straight), lifter down below, remove and inspect. I'm not sure that collapsed lifter could cause a backfire, possible.
    1986 C10 SCLWB 6.2TD 3.73 700
    1989 V20 SUB 6.2NA, 3.73 400
    1994 G20 VAN 6.5NA, 3.42 60E
    1996 K30 DRW 6.5TD 4.10 80E
    Nov 2007
    Hancock MD
    internal crack in between intake runner and exhuast?? did you have heads pressure checked when doing the HG's??
