Go Back   TheDieselPage.com Forums > The Diesel Page Member Forums > Towing - 5th-Wheels & Travel-Trailers
Towing - 5th-Wheels & Travel-Trailers 6.2/6.5 and Duramax towing performance? Towing accessories? Truck/trailer setup? Compare RV trailers? Trailer maintenance? Great destinations & vacations? Anything towing or trailer related.
Old 03-08-2010, 10:04 PM
46stude's Avatar
46stude 46stude is offline
Default '94 1/2 ton towing capacity
My current truck is a '93 ext cab Silverado 2500 lwb w/ the gas 350 & auto overdrive, 2wd.
Looking at a '94 Sierra ext cab shortbed 1500 w/ the 6.5TD & auto OD, 2wd.
Obviously fuel consumption is the main issue.
The '93 gets about 11 unloaded, less than 7 pulling my 5K pound 5th wheel TT. The TT is actually not a strain at all on the '93, but I wonder how much it would affect the '94. The 6.5TD would get better MPG's unloaded, & I think it'd do somewhat better w/ a load as well- not sure
I pull it no more than 3-4 times a yr at most, & the round trips are within 500 miles on mostly flatland w/ some TX Hill Country thrown in.
I figure loaded down w/ people & gear the weight is right around 6200K- prolly a little less. The TT is a 25' I believe (not sure, but it sleeps 4).
I forgot to look at the weight ratings on the truck, but figured some of y'all might know & have some advice. I'd run the trailer brakes of course, & either helper springs or air shocks. I've seen similar yr Z71's pulling TTs as big & bigger than mine, but they're 4wd & have a little more suspension I'm told.
*EDIT*
Oh, I'll be running ~60 mph.... I never run much more than that when pulling any trailer.
Old 03-09-2010, 09:50 AM
JohnC's Avatar
JohnC JohnC is offline
Enemy of the State
Depends...
Does this truck have 5 lug wheels? If so, the rear axle is pretty light duty. Also, what is the axle ratio? The light duty 6.5 will pull pretty well with a 3.73 but if it's 3.42 not so good.
I used to pull a 6000# horse trailer with a LD K2500. Same engine but heavier, 4WD running gear. Also, the horse trailer is probably a little more aerodynamic than the TT. I got 12-14 mpg on the highway.
YMMV
-Joseph Sobran
Gone but not forgotten: '87 F350 7.3, '91 C2500 6.5, '95 K2500 6.5, '06 K2500HD 6.6
Old 03-09-2010, 07:21 PM
46stude's Avatar
Not sure of the ratio. I was just seeing of someone knew the GVRW for these trucks offhand.
And it is a 5 lug rear, but the GM 10 bolt is stout enuff to do the job I'd ask of it. I was more concerned whether the 6.5TD could pull it, to be honest. Never owned one before.
I'll look at the RPO stuff next time I'm near the truck for the ratio & look at the GVRW.
Old 03-10-2010, 12:00 AM
Edahall's Avatar
Edahall Edahall is offline
The 6.5TD should pull better than the 350. For comparisons sake, I pull a trailer of about the same weight as yours with an 82 Suburban that has a 6.2 non turbo and 3.08 axles. It does a dandy job and pulls the grades fine. I get 15-16 mpg towing.
1990 ton 4x4 Chevy Suburban
-Gear Vendors Overdrive
-Upgraded Holset HX-35 turbo
-NP205 iron transfer case
-3.73 gears
1982 ton Chevy Suburban
-Stans headers
-Ported heads
-Timing gear
-4 speed automatic
-3.08 gears
-30 mpg on freeway
  #5
Old 03-10-2010, 12:29 PM
JohnC's Avatar
Enemy of the State
... the GM 10 bolt is stout enuff to do the job I'd ask of it. I was more concerned whether the 6.5TD could pull it, to be honest.
It doesn't take much to make that 6.5 strong enough to tear up the axle. I tore up a 9.5" 14 bolt SF axle with mine.
-Joseph Sobran
  #6
Old 03-17-2010, 08:51 PM
46stude's Avatar
3:42 rear axle, open diff
GVWR 6200/2812
GM trucks aren't really that lightweight, are they? Or am I wrong in thinking the rating is good for about a 3K pound trailer?
  #7
Old 03-17-2010, 09:29 PM
46stude's Avatar
OK, been doing some research.
Where do I find the GCWR? That apparently tells me what the truck can pull.
The GVWR tells me how much weight I can put on the truck.
For comparison, my '93 2500 has a GVWR of 8600 & a 3:73 open diff.
