I had trouble starting my vehicle (03 Duramax) at times hot and cold. It left me stranded twice now after a break from driving a long time. I left the vehilce both times for about 1.5 hours, then I went back and it started. It is very eratic in the start process - sometimes without any problems, other times it will not start. I brought it into the Chevrolet, they quoted me the following:
Fuel API rating too High
Fuel filter housing allowing air into system
The vehicle started 'OK" when I first started it. I'm nto sure its turning over as fast as it should. I then checked for proper max commnad pump pressure. 160Mpa - OK next I check Ed low side vacuum. Pretty normal @4 to 5". testing showed no apparent leakage or air entry . An API test of fuel grade showed it to be fairly high at 42 (compensated to 40) it should be about 37. This generally will cause extended crank times when hot. I tested the fuel system low side and found also that the fuel filter housing is allowing air into syst and preventing proper suction during cranking. The housing should be replaced.
Estimated price - Fuel filter housing - 643.70
Shop time 2.5 hours
Is the diagnosis correct? Is this something that can be rebuilt, or just replaced? If so, how hard is it to do? Any speciality tools? Where should a person get the housing assy? Thanks for any assistance.
