Register | FAQ | Members List | Photo Album | Mark Forums Read |
6.2L Diesel 1982-93 6.2L Diesel - Member access forum for any questions or information exchange related to the 6.2L engine. |
Thread Tools | Display Modes |
I have an 86 Chevy Beauville with a 6.2, and VanDiesel is one of my all-time favorite vehicles, EXCEPT for the engine block coolant drain plugs, which are behind the engine mounts. I badly need to clean and flush the cooling system, and that flush requires draining the block. Does anyone have a suggestion/method for a flush?
Thanks! |
You could remove the block heater on one side, and knock a freeze plug out of the other. No, not a good way to do this really.
Really doing the radiator is a large chunk of the coolant, flushing this is a big help, I wouldn't bother with the block personally. J
1982 C10 SCSWB 6.5TD, mods too extensive to list. (13.69 1/4 mile @94.6 MPH) RACE TRUCK 1982 C10 SCSWB 6.2NA, 2.73 700 1986 C10 SCLWB 6.2TD 3.73 700 1989 V20 SUB 6.2NA, 3.73 400 1994 G20 VAN 6.5NA, 3.42 60E 1994 K20LD ECSWB 6.5TD, 3.42 80E 1995 K20 SUB 6.5TD, Wrecked, ran into by stupid teen. 1995 C3500HD DRW 6.5TD, 12' Flatbed 5.13 80E 1995 C3500HD DRW 6.5TD, 18' Rollback Wrecker 4.63 80E 1994 C20HD ECLWB 6.5TD 3.73 80E Wifes Truck. 1995 C20LD ECSWB 6.5TD 3.73 80E 1995 K20LD SCLWB 6.5TD 3.73 80E 1996 K30 DRW 6.5TD 4.10 80E 1997 C10 Tahoe 2Door 2WD 5.7L to 6.5 Conversion Underway |
Thanks, John. I might just end up doing the radiator only --- that would be much better that no attention at all. And I've looked at the freeze plugs as a possible alternate, but I always come back to, "They didn't really design it that way, did they??" As an engineer, this sort of lunacy hurts!
Perhaps there is a brass street 90 elbow with 3/8 MPT one side and flare fitting outlet, that I could install between the block and the engine mount. If I find one, I'll let you know! Ross |
just stick a garden hose in the water pump and let it run for a while, this is what i do to flush the coolant from the block
EDIT: maybe i should say let the water run for a while and the truck off |
Thread Tools | |
Display Modes | |
