Go Back   TheDieselPage.com Forums > Other Diesel & Truck Related Forums > Diesel Conversions
Diesel Conversions Convert gas to diesel, or convert to a 6.2/6.5/Duramax/Cummins/Navistar/Isuzu/Perkins/Detroit/or ... diesel engine. Go here to see completed projects, works in progress, share your conversion or ask the experts.
Old 08-25-2010, 09:52 PM
b1jetmech b1jetmech is offline
Default 93' Sububrban 4x4 Cummins 4BT
Hello all.
I wish to share some of my conversion experiences with you. I had a 93's Suburban with a 4BT. Between kids in diapers, work and school, it took me a year and half to perform this conversion. After all said it done it turned out pretty good.
Here is the suburban before the conversion.
Rip and tear...work begins at dismantling.
Here is the engine. A 105 horse Cummins 4BT. Final installation of the engine included a 90" 5.9 Turbo H1C with a 12cm housing.
The original transmission was a 4L60E. I preferred a non electronic tranny so I got a internet order 700R4 built for torque. The only problem, the builder didn't include a diesel governor like I advised him to.
First issue. The 4BT is from a GM stepvan which includes a GM adapter and flexplate. The flexplate has a turbo400 torque converter bolt pattern and 700R4's torque converters didn't have th400 bolt patterns.
Issue resolved by having a torque converter shop build me a torque converter with the spring pads located further out to match the TH400's bolt pattern. The torque converter was built including a carbon fiber clutch.
Engine/tranny mated.
Old 08-25-2010, 09:57 PM
Out with the old tired 350.
In with the Cummins. It would be in-n-out countless times until every thing fit nicely.
An AC bracket purchased from the Cummins dealership. This will mount the Dodge style AC compressor high up.
A couple of pics of the accessories mounted.
Problem, the AC compressor interfered with the 4BT's stock horizontal oil filter location. A vertical mount was used from a Dodge 5.9
Old 08-25-2010, 09:59 PM
The 4BT's oil pan interfered BIG time with the 4WD third member. I didn't want to lift the Burb' so I began hacking away at the oil pan untiul clearance was negotiated.
Finally the finished product!
A tight fit but it clears (Whew!)
And now some video action from...
http://www.youtube.com/watch?v=uV903Ai7Uhg
Chase
Old 08-26-2010, 10:10 AM
AVM62 AVM62 is offline
Thumbs up
Very nice. Thanks for posting.
1983 GMC Vandura 3500 Nu-Wa 23' Class C Motorhome
6.2L Diesel, Turbo 400
2015 VW Passat TDI SE, 6 speed manual
Past Diesels
1980 MB 240D, 4 speed manual
1985 MB 300D Turbodiesel, auto
1992 Chevy C2500HD 6.5 Dieselturbo, auto
1994 Chevy C2500HD 6.5 Dieselturbo, auto
2010 VW Jetta Sportwagon TDI, 6 speed manual, sunroof
  #5
Old 08-26-2010, 01:41 PM
93GMCSierra's Avatar
93GMCSierra 93GMCSierra is offline
Did you replace the vacuum booster with the hydro system?
Your vid looks like the hydro setup. but I could not tell.
93 GMC Sierra 2500
6.5L TD Auto
  #6
Old 08-26-2010, 06:54 PM
Edahall's Avatar
Edahall Edahall is online now
The Cummins has a high capacity vacuum pump and works fine with the vacuum booster. In fact, all the older Dodge's with the Cummins engine used the vacuum system.
1990 ton 4x4 Chevy Suburban
-Gear Vendors Overdrive
-Upgraded Holset HX-35 turbo
-NP205 iron transfer case
-3.73 gears
1982 ton Chevy Suburban
-Stans headers
-Ported heads
-Timing gear
-4 speed automatic
-3.08 gears
-30 mpg on freeway
  #7
Old 08-27-2010, 06:16 PM
Thanks AVM!
As far the power brakes I utilize the existing hydro-boost steering system that came with the motor.
The cummins vacuum pump wouldn't fit on this paticular application because it would have interfere with the motor mounts that were used.
If I were to do another cummins swap it would be a 5.9 because it's longer and have more room to locate components like the AC compressor and cummins style vacuum pump.
Chase
  #8
Old 09-09-2010, 07:52 PM
bobbywalter's Avatar
bobbywalter bobbywalter is offline
often, people have to ask if i have a diesel....usually at the gas station.
the funny thing, i test drove a 2wd 1/2 ton with a 4bt in it....could have got the whole rig for a 1000 bux. (i passed on it, and after i thought about it i called to back to buy it so i could part it and it was gone).
it was a beat to **** farm truck but a cummins swap for the ranger for max economy was the goal. didnt take long for me to figure out someone would have to give me a great running complete 4bt power train radiator to transfercase, hopped up to 200 hp for absolutely free....before i would ever put up listening to that thing for 40-100k miles a year.
i have seen turbo 6.2(replaced broke 6.5) burbs like that supposedly getting 26 plus mpg cruise...tried to buy the one truck several times...
cool swap none the less.
whats it like 0-60 and on ramp wise?
88 ranger ext cab low rider 4x4. 6.5 n/a-4l80-f208-spinnin d60's ridin on 33-44 in tires depending on mood that day....and ugly as it gets.
