What gauge combination are you using for your readings?
The factory gauge gives different readings than an aftermarket digital. The factory gauge seems to give a higher than actual reading.
My typical 6.2 gives ~60 psi cold idle, little higher running down the road cold. Hot, I see 35psi idle and around 50-55psi running 2k RPM down the interstate at 70MPH (automatic 700R4 overdrive).
19 psi is not alarming.
Oil pumps vary, mainly in the regulator valve.
Every 6.2 and 6.5 (early 6.5's not later 97's up) have seen the factory gauge as mentioned above.
J
1986 C10 SCLWB 6.2TD 3.73 700
1989 V20 SUB 6.2NA, 3.73 400
1994 G20 VAN 6.5NA, 3.42 60E
1996 K30 DRW 6.5TD 4.10 80E
