Old 03-23-2012, 10:49 AM
Mark Rinker's Avatar
Default Mileage burning #1 vs. #2 diesel
So...I have been under the impression for some time that the BTU content of these blends are the same. However, on the occasions that I have filled with #1 diesel in warm weather, it seems that my average MPG on the DIC begins to climb.
Yesterday I drove unloaded about 180 miles, filled and realized I put in #1 diesel. On the way home, same speed, I added about 1mpg to my average.
Coincidence? Factual? Maybe a tailwind on the way home, instead of a headwind?
Old 03-23-2012, 12:16 PM
DennisG01 DennisG01 is offline
Well, Mark, now you've got me scratching my head! I had always thought that the (very basic) difference was that #1 had slightly less BTU's, but also does not gel as soon. ???
Old 03-23-2012, 03:20 PM
bshull bshull is offline
I was under the impression that #1 had less wax in it so it could resist gelling better at lower temps. With the lower amount of wax came lower BTU per gallon.
I am sure someone will chime in and set the record straight.
Brian
1995 GMC Surburban, 3.42 gears, 4in WarpSpeed Exhaust, Remote PMD, Airdog-100 Lift Pump, Racor fuel filter/heater, S&B cold air filter setup, P-400, ATT, and a Heath tune!
Old 03-23-2012, 04:54 PM
rapidoxidationman rapidoxidationman is offline
the Mercedes forum, Dodge forum, Cummins forum, and some others say:
less BTU's/gallon (137,000 vs 142,000? ish), less paraffin so won't gel as soon, less lubricity because of less wax, costs more, poorer mileage.
Methinks you had a tailwind...
'85 Mercedes Benz 300D, for when I want to be stately.
'05 Mercedes E320 CDI, for when I want to be even statelier.
'05 Chevy K2500 ext cab long box DMax: Everything my '03 was and so much more!
There's no point being a pessimist - it wouldn't work anyway.
  #5
Old 03-24-2012, 08:15 AM
I think it was a tailwind, and a lighter foot on the way home. Average for the 400+ mile day was 19.2mpg unloaded. Not bad!
  #6
Old 03-28-2012, 11:12 AM
tufcj tufcj is offline
On my 2003, I see a noticeable drop in mileage (2-3 MPG) between November-February when they sell the winter blend diesel here in the Denver area.
Bob
tufcj
  #7
Old 03-30-2012, 11:27 AM
More Power's Avatar
Administrator
Hard to gauge what effect it might have for just one tank of fuel, but #1 has less fuel lubricity and can increase fuel injection system wear when used in warmer weather. Here in Montana, we get winterized fuel (mix of #1 & #2) through about April 1st, and am always glad when the pump indicates straight #2. Jim
