Original owner of 2002 Silverado with Duramax 1GCHK29182E119831
Never been on forum so not sure how to proceed but hoping someone out there can help point my professionals in the right direction. Tried to leave for long trip with 23' 5th wheel and struggled to get up to first hill after spending over $7,000 last week to fix low power upon acceleration (P1093 & P1094).
I'm also not mechanically inclined - have to trust the professionals that can't seem to get it fixed after putting in new fuel filter, Air Filter, and all new injectors (2nd set at 178,000 miles - dealer also replaced them at 73,588 miles). Some of the clues/tests/recommendations/notes on the bills I paid include:
Plan to be at Diesel shop Monday morning, but have lost confidence after they were confident it was "fixed" and their dismissive attitude toward other recommendations. Still hoping to get a fix and salvage some part of our long planned trip to Alaska but need something specific for any of the three possible mechanics to try (with my money ).
- Dealer: Road tests inconclusive due to different faults possible - wait and see after first time codes appeared a year ago on way back from camping trip
- Independent mechanic with Duramax training:
- "Inspected fuel hoses between Filter and Pump - changed one but all hoses are cracking and need to be changed with correct type of hose" (next expert at diesel shop[below] said they looked/felt fine so didn't change)
- "Monitor BARO and Boost - Match 98 KPA @ idle and Boost 206 KPA @ RPM - Normal at time tesed - suspect Sticking Waste Gate"
- "Monitor Suction side 4.5 in. @ WOT Park and 8.0 in @ WOT Driving"
- "Control Pressure Reg. to max. 160 and no change in Act. Pressure"
- Test Return Flow Cranking @ return line to tank - 60ML in 15 sec."
- "Suspect Leaking Pressure Limiting valve or leaking injectors." (I believe he said his Duramax decision tree pointed to low pressure fuel side initially but some quirk in the decision tree [That I didn't understand] ultimately lead him to the high pressure side)
- Referred to Diesel only shop as didn't have time & thought problem was deep inside motor (where he had limited experience) so made following notes for Diesel mechanic:
- Inspect fuel hoses between filter and Pump and change at least one
- Suspect leaking Pressure Limiting Valve, or Leaking Injectors
- Diesel shop determined:
- Reviewed all the work done earlier this week and the recommendation/suspicions from that testing
- the problem was identified as being the injectors with at least a few of them not working ("Noticed that several injectors when shorted the RPMS would not change"). Wanting to keep truck long term and short of time jointly decided to not test injectors further, just replace them.
- "2 injector housing pulled up with injectors - installed 2 new injector housings with seals"
- Seemed to not understand or discount(?) above recommendation to check "Pressure Limiting Valve" before and after installation of injectors
- Felt that the fuel hoses between filter and pump seemed fine to him and that these low pressure fuel lines rarely have any problems so he chose not replace hoses.
- Indicated I should still experience black smoke but it should reduce over time as exhaust system clears from injector problem.
- Finally out of the shops with trailer in tow yesterday I was nervous first few miles and then very concerned when couldn't hold 40-45 on steep hills where others including heavily loaded old VW Van passed me . Turned around after 100 miles - calculated 10 miles/gallon when identical trip/trailer got 14 when new. Black exhaust still very visible on any acceleration after 200 miles out of shop. Too late on Friday nite to get hold of anyone.
What suggestions/observations do any of you have?
Desparate and extremely frustrated with truck? mechanics? both?
Ken Miller
