Old 08-23-2012, 12:30 PM
BrentN BrentN is offline
Default Fuel Tank Sock Part Number
Going to drop my tank this weekend and give it a thorough cleaning. Had a batch of bad fuel...gunked up a couple of filters, so my sock is likely in as bad of shape.
Does anyone have a part number and source for an aftermarket fuel tank Sock? Called GM and they dont carry (or so they claim), but were happy to sell me a $400 sending unit with it included. Napa didnt either.
Thanks in advance.
BrentN
1999 Suburban 2500 4x4
167,500 miles,4.10,K & N Air Filter
Kennedy 3.5" Exhaust, Remote Mounted FSD Cooler
Kennedy Boost Fooler, Homemade Intercooler (Dieselpage Model)
Derale Fan Cooled Tranny Cooler (under body mount)
A Pillar Pod (Isspro Boost, Pyro & Trans Temp)
2000 Jetta TDI 1.9, Lots of power, 50 mpg, 205K Miles
1982 Rabbit 1.6 NA, Not so much power, 50 mpg-gets the job done
1998 Dutch Star 38' Diesel Pusher, 8.3 Cummins, Allison 6 spd, 9.9-10 mpg
Old 08-24-2012, 05:37 AM
sctrailrider's Avatar
sctrailrider sctrailrider is offline
Diesel junkie
You would maybe be better off to remove the sock and add a pre LP filter, they can be found cheap at NAPA and are easy to install, no more clogged socks... while you have the tank down you might want to install the new style P/U & sending unit, no more gauge bounce and much more accurate tank readings.... I don't know if I am allowed to post a link to the part here, I don't think any of the vendors here sell it, PM me if you want the link..
You can clean the sock very easy, if it's not coming apart..
1993 Chevy K3500
like us on Facebook
Old 08-24-2012, 06:55 AM
Kennedy Kennedy is offline
Default Don't do it!
Recurring theme as of late. Aftermarket sender (with sock) and hair pulling headaches ensue.
Aftermarket parts are often good, but more often inferior as has been the case here. Ask Casey (Arveetek) and I think there was one other that followed shortly after.
Just took a call yesterday from a guy with a 93 and new aftermarket sender. Truck went like 200 miles then shut off with filter full of air.
Old 08-24-2012, 10:01 AM
Diesel junkie
John, do you know what brand it was, I have had very good results with the one I installed, hope it doesn't croke on me now....
1993 Chevy K3500
like us on Facebook
  #5
Old 08-24-2012, 09:40 PM
Thanks all. I will pull it down and give it a good soaking and a wash as well as the tank and put it back together. If it is trashed I will order a new sending unit.
BrentN
  #6
Old 08-25-2012, 07:38 PM
arveetek's Avatar
arveetek arveetek is online now
Moderator-Towing Forum
Yeah, it took me several months to figure out that it was the aftermarket "sock" that was squeezing down and shutting off fuel flow. I reinstalled the OEM "sock" and all has been good since.
I don't know if you can even find an OEM "sock" by itself. Like the original poster, the only option I found was a GM sending unit assembly with an insane price tag.
If you really do have a clogged OEM "sock", you should be able to take it off and clean it well with brake cleaner or some other solvent, and be back in good shape.
1995 K1500 Tahoe 2 door, 6.5LTD, NP241, 4L80E, 3.42's, 285/75R16 BFG K02's, Kennedy OPS harness, gauges, and TD-Max chip, Dtech FSD on FSD Cooler, vacuum pump deleted, Turbo Master, 3.5" Kennedy exhaust, F code intake, '97 air box, dual t/stats, Racor fuel filter, 320K miles and running strong!
  #7
Old 08-25-2012, 11:08 PM
Thanks Casey. Didnt get to the cleaning this weekend. Maybe this week. Always something coming up.
BrentN
  #8
Old 08-26-2012, 03:29 AM
Diesel junkie
I found this....
Part: Fuel Tank Sock
Part Number: 25055272
Manufacturer: ACDELCO
1993 Chevy K3500
like us on Facebook
  #9
Old 08-26-2012, 08:49 PM
Thanks for the part number
BrentN
  #10
Old 08-27-2012, 08:47 AM
DennisG01 DennisG01 is offline
Brent, if you have time, could you post as to "how" you went about dropping the tank and how it went for you? It doesn't look to be all that hard, but I sure wouldn't mind reading about your experience.
