Did you ground the glow plug that you tested with?
Try cleaning and tightening the connections at the glow plug relay. Could be a bad relay, but try cleaning/tightening first. I have seen threads about people changing out to manual, but generally speaking the relay is pretty reliable. There's a good chance the one you have is original - can't argue with that lifespan.
