I want to add a By-Pass Oil filter to my truck and would appreciate recommendations.
Naturally, I'm looking for the "Sweet spot"...ie best performance,value and easy of installation on a Dmax.
Thanks in advance
Web
Thanks in advance
Web
2003 GMC D/A 2500HD SB 4x4, Pewter, Banks Stinger, pulling a 13K Alpenlite 5th wheel nearly full time.
I have the Oil Guard bypass and very happy with install, quality, etc. I wanted the single element so I could continue to use OEM mount with Baldwin filter. Only have about 3K since installed and haven't an analysis done.
03\' 2500 HD LT CC 4x4, D/A, Rancho 4\", Weld Evo\'s, BF 315-70R17 KO\'s, Autometer gauges, Banks 4\", AFE Stg II, LineX, Bilstein SS shocks, OilGuard, Racor 660 Pre-oem, Juice 4.61 <a href=\"http://home.comcast.net/~tophog/duramax/2003_dmax.htm\" target=\"_blank\">(Photos)</a>
I also have the OilGuard and am pleased with it. It is a high quality unit and was easy to install. [img]smile.gif[/img]
With the bracket I have you can mount the Amsoil dual filter bypass unit just behind the stock oil filter. It mounts on the frame is very strong and will take about one or less to mount.
Greg
I've been running the Amsoil dual remote (BMK-17) with great success. I frame mounted mine on one of Greg Landuyt's brackets that I modified for centering between the torsion bar and front drive shaft and to fit up higher against the cab floor. Oil analyses at 63,000 miles have been great.
Love the AMSOIL filters. I'd mount a second one if I could!
Mike [img]tongue.gif[/img]
Been running the Amsoil with Greg's bracket. Only one problem that I cannot explain. Last Saturday the bypass element came loose and dumped a quart on the driveway. I was the HUGE puddle when backing out and paniced. It was loose but had been on for about 5000 miles. I did just finish a trip to KC for about 1200 miles, but I didn't think vibration would do that. I do watch when I back out a little more than before.
02 2500HD LT Dmax/Alli CC 4x4 Lt Pewter, Tan in, Amsoil, transynd, Bilsteins, Amsoil Air Filt, JK 4\" Exht, RollnLock, Rhino Liner, Remote start, alarm, High Idle, SPA DG211, Pred, Mega, Fumoto, Remote oil bypass, XL Tranny cooler, XM, Cell kit
Excuss the lack of knowledge here, but why an oil bypass, what does it do, and what is lacking in the stock configuration to make this mod worth while?
03 D/A CC SB 3/4T 2WD New<br />86 6.2 LB 3/4T 2WD 170K
Trip, the bypass filter adds a second, more effective, filter to the oil filtering system - much like the additional filters many people are adding to the fuel system. It puts a remotely mounted filter pair running in parallel, one full flow and one extremely fine bypass cartridge. The system provides no loss in oil flow (important to preserve lubrication) and the bypass filter removes small debris and carbon that a full flow cannot by continually filtering a "bypass" percentage of the oil. Over time, all the oil gets treated by the bypass and contaminants and abrasive soot is greatly reduced. With modern synthetic oils, the most limiting factor in a diesel application is the inevitable buildup of abrasive soot particles. Without the soot, the lubricity and additive pack in synthetics are good for 100,000 miles or more of use. Many fleets and some individuals use bypass oil filtration and oil analyses to determine when to change out the oil for extended use. I use the bypass filtration for keeping my oil clean and ease of filter replacement and still change on a regular interval of 7,500 miles (although I do have my used oil analyzed). I change the full-flow cartridge at every change (or 7,500 miles) and the bypass cartridge every other change (or 15,000 miles - same time that I change my OEM fuel filter).
Trip, I posted this for another member, hope it helps.
Newbie
Member # 10195
posted July 31, 2003 03:17 PM
Have been reading this thread on syn. oil. Hope this helps. I have over 235k miles on my 02 D/A I switched to Amsoil after iniatial break-in, recommended by Amsoil,(15k). At that time I installed the by-pass filter system also. Now,at regular OEM oil change(7500 miles) you change the primary filter only & add what oil was lost.When it is time to change all the oil, you change both filters. I have run this oil over 60k got nervous & changed it, sent in a sample. It was "STILL OK" for continued use. What does the motor look like? At 215k or so, had a couple injectors go bad, Chevy service dept.said it looked as clean inside as a new motor.Gonna try for 80k befor changing this time(keep sending in samples though}. If your sample shows up bad Amsoil will call you right away & tell you. If oil is still good report comes in the mail. This truck is towing all sorts of trailers & loaded 70 to 80% of the time. Bill
Bill<br />hd90rider@aol.com<br />02 Chevy 3500 Crewcab Dually<br />Amsoil bypass<br />K&N Filter<br />115 Gal for cruisin !!<br />RV & Boat Transporter<br />Need one pulled somewhere???<br /><br />03 Anniv. H/D Ultra<br />2000 Ultra for sale
Seems like people like either the OilGuard or Amsoil units.
Does anyone know if there performances are about the same?
Idle_Chatter & hd90rider
Thank you very much for the valuable info. I am now "in the know"! I can see that an oil bypass is in my future. That's what great about this forum...people here like to share...again, thanks. [img]smile.gif[/img]
Done a pre and post oil analysis with the Oil Guard filter and saw a significant improvement. Can't say which is better though. Haven't tried the Amsoil element. However' I'm very pleased with the Oil Guard quality and cost of replacement elements.
2002 2500HD CC D/A <br />Post Mega filt., Lighted TTT mirrors, K&N Air Filt, Bilstein <br />B&W Gooseneck/5th, Oil guard, <br />Tekonsha Prodigy, Lift Pump, Line-x<br />Air Lift Bags & Load Controller II <br />Pics. <a href=\"http://community.webshots.com/user/abear130\" target=\"_blank\">http://community.webshots.com/user/abear130</a>
