Does someone have the ability to check this Vin # for warranty work etc?
1GCHK29255E114101
Thank you,
Dan
1GCHK29255E114101
Thank you,
Dan
Dan<br />1995 K2500 6.5 TD, 4\" Exhaust, Air Mods, Boost,EGT,Tranny Temp Gagues. Heath balance flow system, heath chip, heath turbo master, B&M deep tranny pan
Have you tried calling the dealership? I just did
this yesterday and the service manager was kind
enough to run the report and fax it back to me.
The report actually had the website address where
he got the info from, but unfortunately, it's
password protected.
VIN : 1GCHK29255E114101
VEHICLE INFORMATION
Merchandising Model : CK25753 -2005 SILVERADO LS 2500HD 4WD EXT CAB Warranty Start Date : 03/11/2005
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : PARKER CHEVROLET-OLDS-PONT, INC.
PO BOX 308
CHAMPLAIN , NY 12919-0308
(518) 298-8272
Selling Source : 13 - CHEVROLET
Site Code : 32177
Business Associate Code : 115064
Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Type Number Description Posted Date Status
RC 05006 HYDRO-BOOST ACCUMULATOR OVER-PRESSURIZATION N/A Closed
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
Vehicle Has No Associated On Star or XM Radio Information.
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER 03/11/2005 128 miles 03/11/2008 36128 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH 03/11/2005 128 miles 03/11/2011 100128 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 03/11/2005 128 miles 03/11/2013 80128 miles
60/50000 CALIFORNIA EMISSIONS 03/11/2005 128 miles 03/11/2010 50128 miles
84/70000 CALIFORNIA SELECT COMPONENT 03/11/2005 128 miles 03/11/2012 70128 miles
60/100000 GM DIESEL ENGINE IN LIGHT DUTY VEHICLE WITH $100 DEDUCT AFTER BUMPER TO BUMPER 03/11/2005 128 miles 03/11/2010 100128 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
04/27/2005 033068 # B8968 - MOLDING, TAILGATE/LIFTGATE OUTER PANEL - ONE PIECE - R&R O 1349 miles
04/27/2005 033068 # E7020 - WHEEL, STEERING - REPLACE 1349 miles
04/27/2005 033068 # V1308 - 05006 - INSPECT HYDRO-BOOST - NO FURTHER ACTION REQURIED 1349 miles
08/19/2004 A14101 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
GMC Tech,
Could I impose on you to check out the following
VIN:
1GTHK23143F109642
I'm thinking of buying this truck, so i'm
interested in its history. If it's a pain to cut
and paste the info, I'd appreciate your opinion
of the history (e.g. "too many problems with
that truck"). I'm sure you don't a lot of people
asking for VIN checks, so prefer not to, then I
understand.
THanks
Thank you very much GMC Tech, I appreciate it !!!!
...not trying to impeed, just thought I could help you out quicker.......also it has two open recalls.
07/08/2005 030410 # C6871 - COVER AND/OR PAD, FRONT SEAT CUSHION - LEFT - R&R OR REPLA 45174 miles
07/08/2005 030410 # D1180 - SWITCH, PRESSURE CYCLING - REPLACE 45174 miles
07/08/2005 030410 # N6620 - WIRING AND/OR CONNECTOR - POWER & GROUNDS DISTRIBUTION - R 45174 miles
07/08/2005 030410 # N9995 - CUSTOMER CONCERN NOT DUPLICATED 45174 miles
01/07/2005 254109 # C3200 - PANEL, CENTER PILLAR TRIM FINISHING - RIGHT - R&R OR REPLA 35987 miles
01/07/2005 254109 # N4180 - CLUSTER ASSEMBLY, INSTRUMENT PANEL - R&R OR REPLACE 35987 miles
12/10/2004 252792 # N4187 - INSTRUMENT CLUSTER-ASSEMBLY RETURN TO AC DELCO ESC 35478 miles
12/10/2004 252792 # V1242 - 04007 - INSPECT AND REPLACE TAILGATE SUPPORT CABLES INC. H 35487 miles
08/17/2004 148727 # N6610 - WIRING AND/OR CONNECTOR - ENGINE WIRING - REPAIR OR REPLAC 28560 miles
08/17/2004 148727 # K4122 - MODULE, TRANSFER CASE SHIFT - REPLACE 28560 miles
08/17/2004 148727 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 28560 miles
10/02/2003 230488 # N6620 - WIRING AND/OR CONNECTOR - POWER & GROUNDS DISTRIBUTION - R 100 miles
10/24/2002 097805 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 14 miles
Thanks MadMatt. For me, the report is not a
favorable one. Oh well, there will be other
trucks. [img]smile.gif[/img]
it doesn't look all that bad although it does appear that it's had some sort of wiring problem since new.
I suppose the repairs can't be considered too
serious, but a couple wiring problems, transfer
case module, instrument cluster R&R, pressure
cylinder switch(?)...
Btw, this is the truck I'm looking at:
http://cgi.ebay.com/ebaymotors/GMC-S...88544314QQrdZ1
the pressure cycling switch is fairly common and I've changed out a few IPCs. reprogramming the TCMs is done everyday as well ,but I've yet to replace one as the history states. as far as the wiring problem goes, it hard to tell just from reading a VIS entry. these entries are rather vauge usually and who knows who was working on it. it might have been an easy fix for an experinced tech who deals w/ these trucks day in and day out but would simply baffle a lesser tech.
Matt,
Can you email me at: reyb92129@yahoo.com
