Page 6 of 6 FirstFirst ... 23456
Results 101 to 108 of 108
Thread: High Miles contest!
  1. #101
    Thumbs up
    I'm at 320K miles on my 1995 6.5L now. She is showing no signs of slowing down or wearing out either.
  2. #102
    Jun 2017
    Rutland, VT
    Default Mileage
    Forgot to mention my truck is a 04 with the LLY. All stock.
    Thanks for the advice More Power.
  3. #103
    Jan 2006
    South Milwaukee, WI
    Default Late entry!!!
    I know it's a late entry, but I'm attempting to post a pic of my Odo from my (former) 2001 2500HD. 436,767. Recently sold....
    (somone let me know if it doesn't appear anywhere...)
    "Chessy56"
    So. Milwaukee, WI
    '01 2500HD, LB7, ~440K miles
    Winston Churchill
  4. #104
    Dec 2005
    Klamath falls/keno Oregon
    Hummer wheels :^)
    dual lift pump
    Banks air intake
  5. #105
    Oct 2006
    new brunswick
    05 gmc 3500 497,ooo kms and still good
    2005 gmc 3500 c/c 4x4 dually 2015 Sierra 377FLIK 14,000lbs
    Rebuilt Allison w/ billet torque converter and upgraded clutches
    lly Duramax
    edge juice w/attitude
    Kennedy boost stick
    banks air box
    MBRP 4" SS
    egr blocker plate and finger stick
    head studs
  6. #106
    Dec 2005
    Wow that’s cool maverick_935..
    Hummer wheels :^)
    dual lift pump
    Banks air intake
  7. #107
    The ol' Tahoe made it to 375K miles before popping a head gasket in July of 2021 - she showed no symptoms of any issues at all, but suddenly popped without warning, causing the rear two cylinders to fill with coolant when sitting for more than a few moments. I could have slapped some gaskets back on and called it good, but ended up rebuilding a low-mileage 506 block to drop in, and I've currently got around 390K on the clock and about 15K on the new engine.
  8. #108
    Feb 2024
    US El Sobrante California
    Default High milage?
    Don't know what happened to my post, but mine is a 2004 GMC 2500 with 252116 miles. No real problems but glow plugs, vacuum pump and batteries. Sorry previous post I was guessing milage, this is the actual as of right now.
