My first time changing the fuel filter. A few observations that might help someone. You can stop reading here if you've already done it!
1) Even if you don't plan to change your own, but keep one in the truck "in case", do it once in your own driveway.
2) Mine will not come out through the top (without removing the battery).
3) Even if you plan to go from the top, take of the fender well so you can get a look at everything once. I found one wiring harness going under the filter, and then clips that needed to be opened to move it. A second harness along side the harness which pushed out on the filter when trying to reinstall. Tied it up and back so I could thread on straight.
4) While threading on the filter I found the water sensor wires were catching on the lower wire harness and twisting. I taped then to the filter while installing. Or you could install the water sensor after installing the filter. I think its real expensive to replace the sensor if the wires got twisted off.
(And one embarressing moment. Couldn't get the filter pushed up to where it would catch the threads. Finally looked at the old one and saw that there was no center rubber gasket like the new one had. And there was the old one still on the filter mount. Wouldn't have seen this working from the top. Couldn't get it off easily and had to leave soon so I just left the old one in place and removed the one in the new filter.)
Hope this helps someone [img]redface.gif[/img] )
