Thread: Drop in oil pressure with Rotella synthetic?
    Lake Charles, LA
    Tell me I'm worried for no good reason. I changed my oil a few days ago to Rotella synthetic 5w-40. 18,000 miles up to that point on Rotella T 15w-40. I also changed the fuel filter. I've noticed that my oil pressure at idle when the engine is warm is lower than it used to be. On the dino Rotella it would drop to ~40 psi at idle. On the synthetic it drops below 40 to the next small line on the guage, about 35 psi (guesstimate), at idle. Is this a problem or anything I should be worried about. Has anyone else noticed it when changing to synthetic?
    Maybe its just wishful thinking, but I think I noticed a difference after changing the fuel filter. Seems a hair quicker on acceleration.
    \'01 2500HD D/A CC SWB 4X4<br />Plain old white<br />Linex Bedliner<br />Husky Liners/Mudflaps<br />Kennedy\'s Headlight Harness<br />Black Westin WTW bars<br />255/85 Trxus MT\'s<br />GO HOGS plate on front
    Ct.
    SWLA,
    Mine is in same place...Full operating temp at idle running 15w40 Amsoil synthetic......
    MAC
    The Juice box will give you a whole head of hair.....
    The Super juice will toss in the hat !!!!!!!
    [ 09-29-2002: Message edited by: mackin ]</p>
    LanduytG Guest
    A small drop in pressure is not uncommon when switching to a synthetic. Just because you have a drop does not mean you don't have flow. Really it's nothing to worry about.
    Greg
    Cov. Ky.
    I just switched to Rotella 5w40 and the oil pressure is the same. 45psi at idle and 75psi on the road running. I was running Delo 15w40 before this. 35,000 miles and temp outside around 75 degrees.
    2001HD,4X4,CC,D/A Driving it since, 12/20/00--58,000 miles.<br />Two tone paint, silver/blue.<br />EGT gauge,265 OWL tires.<br />1.10 Predator, 4\" Magnaflow muffler, Amsoil air filter.<br />1982 Toyota, 35\" Boggers, 529:1, locked, exo cage.
