I was looking around on the www.gmupfitters.com site when I stumbled across the high idle publication. It says this:
"HIGH IDLE PROCEDURE FOR C/K 2500HD & 3500 SERIES TRUCKS WITH 6.6L (LB7) DIESEL ENGINE
bulletin zyk 53 11 of 28 2/11/02
High Idle can be obtained by using the 8-pin PTO connector behind the dash and the PTO
accessory kit. The PTO connector can be found behind the passenger air bag defeat switch. It
should be taped to the IP harness directly behind the passenger air bag defeat switch. Mount
the PTO switch next to the passenger air bag defeat switch.
The PTO interface wiring harness included with the PTO Kit is not needed unless
a requirement for remote operation is desired.
Connect the Tech 2 scan tool and reprogram the Engine Control Module (ECM). See the PTO
Programming Guide section for instructions on how to get to the PTO programming screen.
Remember to program to either the Preset PTO or Variable PTO Mode when
using the PTO switch. When the PTO settings are initially read, the settings will
show values of 6000+ rpm. Select the Change Options menu and continue with
the reprogramming of the ECM.
The changes that need to be made are as follows:
PTO Max. Engine Speed 2200 RPM
PTO Standby Speed 800 RPM
PTO Set Speed 1250 RPM
PTO Resume Speed 1700 RPM
PTO Max. Engage Speed 1000 RPM
PTO Shutdown NO
PTO Engage Relay NO
PTO Feedback NO
NOTE:
If the reprogramming of the ECM is not performed, the High Idle function
will not work.
To engage the High Idle, set the Park Brake (manual transmission only) or put the truck in
PARK (automatic transmission only), turn the switch to the ON position. Move the PTO switch
to the SET position or press the SET switch on the cruise control stalk, if equipped. The SET
input ramps up the engine speed to 1250 RPM. By pressing the cruise control, RES/ACC
switch the engine speed will increase to the PTO Resume Speed setting and any SET input will
decrease the engine speed to the PTO Set Speed setting.
If the truck does not have the cruise control option, only the PTO Set Speed is available. The
PTO/High Idle settings can only be changed with a Tech 2 scan tool. The Tech 2 scan tool can
be purchased from GM by calling 1-800-GM-TOOLS.
The PTO accessory kit is available from your local GM dealer.
If any problems should arise, check and clear any DTC's with a Tech 2 and make
sure that the brake switch and tail lamps are functioning correctly.
NOTE:
In certain cases the PTO wiring and connector will not be installed behind the
passenger side air bag switch. If this is the case, the system will need to be hardwired
into the ECM and a switch or switches (no cruise control) will need to be
used. Please call the Upfitter Integration Hotline at 1-800-875-4742 for more
information."
It says nothing about running a wire to the ECM. I have a PTO switch but no Tech 2. I was curious if anyone out there had tried this with the PTO switch and a Tech 2 and if it works. I'd be willing to send someone my PTO switch to try this out if they have a Tech 2. I know a few of you guys have played around with the Tech 2 and the high idle, but I think that was with high idle hard wired to the ECM.
