Here is the setup:
No squeak:
Engine cold
Engine warm/hot without shutdown
Big squeaky, squeaky, Just a little bit louder than the tick:
Engine warm/hot - shutdown for a couple of minutes squeak is apparent from idle until 1500 rpm, squeak will increase with speed.
Tech tried the belt first then replaced alternator, assumed bad bearing, squeak now gone, however, BIG WARNING, make sure tech. is very good. The tech's wrench slipped of the nut and trashed my AC line. I know can happen to anybody, but I bet it won’t happen to this tech again. No AC line in stock won’t be here until Monday 4/22, dealer has had my truck for two days on this. I'm going to pick it today and bring it back again when the part comes in.
- You may not post replies
- You may not edit your posts
Forum Rules
