Has any body added engine oil temp gauge? Where are would you reccomend mounting sender unit.
BRS<br />2001 2500LT,CC/SB,D/A,(ALL INDIGO),<br />265/75 Michelin M&S,Access Cover, Pop Lock Electric TailGate Lock, Westin CPS Bars,Vent Shade Taillight Covers & Step Sills,45 Gal. American Aux.Fuel tank,HomeLink,Oil Temp-Boast-Pyro Pillar Pod,Escalade Steering Wheel Radio Controls,Putman Box Rails, Allison Deep Pan,Fumoto Drain,Lighted Sun Visors,Reese 5th Wheel Hitch,XM Sky-FI.
I'd recommend somewhere near the oil. Just kidding.
I've got one installed in the oil filter mount. I removed a 3/8 NPT plug and used an adapter to fit the sender. The trick is to get the sender as close to the flow as possible without obstructing it.
Click on truck pics below to see the actual location.
Hope this helped, Regards, Steve
\'02 2500HD 2WD LS, grey, CC, SB, D/A, locking diff., alloys, trailer and towing pkg. Delivered 11/09/01<br />So far:<br />Juice ver 3.61c, Max Power Plug, PS2000 propane, Gibson Performance dual exhaust, 255/85-16 Dunlop Rover A/Ts<br />Pillar mounted SPA Boost/EGT/oil press./oil, tranny, diff. temp gauges, Valentine One<br />Aiwa CD/MP3 head, 4- Pioneer TS-C1653 6.5\" component spkrs, 2-10\" Tsunami subs, 1200W of Visonik amps<br />Jordan 2020 Ultima Brake Controller, Lucerix mirrors, Line-X, Bed X-tender, DeeZee running boards<br />Peragon folding bed cover, Rancho RS9000 shocks<br />PIAA headlights, Power tailgate lock, Invinca-shield, Husky flaps and tinted windows <br />Mag-Hytech diff. cover, Allison deep sump, Transynd, Amsoil air filter and gear lube, Fumoto valve<p>Up next:<br />high idle, Spare fuel tank?<br /><a href=\"http://www.pbase.com/sfrakes/2002_silverado\" target=\"_blank\">Truck Pictures</a>
I mounted mine where SoCalDmax recommended and it works fine. My oil temp runs from 195 - 215. When pulling my 5er this weekend it was running 215. Coolant temp was 191. I have a digital coolant temp gauge also.
[ 04-21-2002: Message edited by: Joe Dawson ]</p>
2001 GMC 2WD 2500 HD D/A CC Long Bed 6500 lbs.<br /><b><a href=\"http://www.airliftcompany.com/superduty.htm\" target=\"_blank\">AirLift Superlifts</a></b> , <b><a href=\"http://www.lucerix.com/xmount.htm\" target=\"_blank\">Lucerix Mirrors</a></b><br /><b><a href=\"http://www.fumotovalve.com/merchant.cfm?id=88&step=2\" target=\"_blank\">Fumoto Drain Valve</a></b> , Delvac 1<br /><b><a href=\"http://www.pecuniary.com/synthetics/bypass/dualremote.html\" target=\"_blank\">Amsoil Dual Remote Oil Filter</a></b><br /><b><a href=\"http://www.campingworld.com/browse/skus/index.cfm?skunum=18009&src=SRCH&tcode=37\" target=\"_blank\">Chieftain Air Horns</a></b><br /><b><a href=\"http://www.duallydepot.com/\" target=\"_blank\">53 Gal Fuel Tank Toolbox Combo</a></b><br /><b><a href=\"http://www.dtacorp.com/index.htm\" target=\"_blank\">DTA Running Boards</a></b><br /><b><a href=\"http://www.dakotadigital.com/index.cfm\" target=\"_blank\">Dakota Digital Gauges</a></b><p><b><a href=\"http://www.sunnybrookrv.com/\" target=\"_blank\">2001 Sunnybrook 31ft. BWFS</a></b><br /><b><a href=\"http://www.precisiontemp.com/RV-500Page1.html\" target=\"_blank\">Precision Temp Tankless Water Heater</a></b><br /><b><a href=\"http://www.fortunecity.com/marina/finisterre/1228/jorjan/index.htm\" target=\"_blank\">Jordon Ultima Controller</a></b><br />Honda EU 3000 Generator
Joe Dawson, you wrote
"My oil temp runs from 195 - 215. When pulling my 5er this weekend it was running 215. Coolant temp was 191. I have a digital coolant temp gauge also."
What temp did you see on the stock temp gauges?
I've found that the factory temp gauge is off by about 5- 10 degrees. On the lower end of the scale the temp is off by about 10 degrees. At operating temps it is off by about 5. When I was at 191 the stock gauge was about 195.
I had a sensor that replaced the oil pan plug on my D**ge. It was pretty worthless. It would only show a temerature rise at idle or when the ambient temperature was real hot. It showed very little difference on what kind of load I was pulling.
Roger
2003 Silverado LT, Long Bed, Extended Cab, Victory Red.<br />Replaces 1990 Dodge Cummins with 360,000 Miles Red.<br />Id Rather be Flying!<br /> <a href=\"http://www.picturetrail.com/aoparoger\" target=\"_blank\">www.picturetrail.com/aoparoger</a>
