I am haveing a small problem re-engaging or accelerating with the cruise control when it is cold out. Once the inside of the truck warms up I have no problems. I am convinced it has something to do with the sensor for the clutch. From what I can tell the sensor is around the clutch rod that passes through the fire wall. It probably serves 2 purposes, 1. senses the clutch pedal is in to allow the truck to start, and 2 dis-engages the cruise when the clutch pedal is depressed. I have had no problems starting the truck. It always cranks. But today once again the cruise wouldn't re-engage, or accelerate. It was 30 degrees out today. Once the truck warmed up a little it worked fine. Last week it was in the 70's and I had no problems. I'm hoping one of you 6 speeder's out there knows more than me about this. Do any of you know how the clutch sensor works?
