Results 1 to 16 of 16
Thread: synthetic oil
    Apr 2002
    Canada
    Bought my first diesel 2500HD last year and am thinking of using synthetic oil in the front axle and transfer case. According to the dealer the rear differential comes factory equipted with synthetic oil. I have about 7500 miles on it now with 100 miles under load (4 wheel). Any suggestions on type and grade of oil to use.
    Jul 2001
    Tremonton, Utah, USA
    Talking
    I have run Mobile 1 front to rear in my last three trucks with good success. I have Amsoil in the engine on this one. Later! Lone Eagle
    02 2500 HD EC SB<br />Juice 4.61<br />Post OEM Racor 660<br />Back Country Bars<br />Roll Lock Cover<br />B & W Turnover
    Aug 2001
    St. Louis, MO
    I'm running Mobil 1 synthetic in the rear and Redline synthetic in the front. Any high quality GL-5 synthetic gear lube will work fine.
    Don't use Mobil 1 motor oil. It's not rated CH-4. Use Delvac 1 instead if you like Mobil products.
    [ 04-22-2002: Message edited by: csimo ]</p>
    Mar 2001
    Atlanta, Texas
    how many qts are in the front end??
    2001 JUICED GMC 2500HD SLE AlliMax, Longbed, Ext. Cab, 4X4 Summit White, G80 Differential, Husky Liners, Black UWS Toolbox, Black Westin Nerfs, Black Replacement Front and Rear Bumper, Black Bedrail caps, Autopage 2 way LCD Alarm remote start,JL Audio, Hella, Cobra, ProComp Mud Terrains, Tekonsha Prodigy Controller, Fumoto, Rhino Liner, 400 Watt Inverter, Pioneer XM Radio<br />KENNEDY 4\" Exhaust. 100,000 miles on January 31,2003!!<br /><a href=\"http://home.att.net/~markstanco\" target=\"_blank\"><b>PHOTOS UPDATE 11/02</b></a><br /><br />Gutter Pipe is your friend. Leafblower is your enemy.
    LanduytG Guest
    Alli-max
    You will need 2 quart.
    Greg
    Mar 2001
    Atlanta, Texas
    Gracias Gregory!
    Columbia, TN USA
    I'm getting ready to change all the oils front to back before heading out to BC. I have not seen what is required in the transfer case for the 4x4. Is it Dextron III?? How much??
    Thanks guys for the help.
    Mar 2002
    meridian, ms
    cmadmaxman ,
    I think the product in the transfer case is called transblend and is only aavilable at GM dealer. If I am not mistaken your owners manual says on most lubes use GM or equivalent, but not for this lube, so I guess you better go with GM. Check your manual, I would look for you but I am too lazy to get up and go get mine.
    Todd Eldridge<br />2002 2500HD Crew 4x4 zf 6sp<br />Stanadyne FM-100 additional fuel filter<br />Flo-Pro Muffler<br />Summit White <br />Fender flares painted to match<br />GMC side molding<br />SS Nerf Bars<br />e-mail todd.eldridge@cnet.navy.mil
    Columbia, TN USA
    Thanks srubrn.
    Now that I think about it, I remember something like that. The problem was that it was talking about the HD with the 6.0 gaser transfer. Not the one attached to the allison. With the allison transfer case we don't have auto track like I had with the 6.0 gaser that I had in the 2500. Will do some more checking and look into the owners man. deeper. Any more ideas??
    2001 Chevy 2500HD LT D/A, 4X4 Crew Cab 265 75R 16 Michelin LTX M/S Luverne SS boards, Isspro EGT & Boost, AFE stage 2. Quadzilla tow tuner, Mobil 1 front to back. (TOTALED 06/07)
    1995 2500 x-cab 6.5 TD, Pinnacle Exhaust, AFE Stage 2 intake.
    cmadmaxman is right. The transfer case in the HD's requires Dexron III (dino or synthetic). It is not an Autotrac transfer case, which requires Autotrac II fluid. The Autotrac is the transfer case on vehicles equipped with Autotrac (as an option, not all of them), like a 2500 (not HD), 1500, Tahoe, Yukon, etc. Push button 4X4 does not mean that you have Autotrac. It is the same as a manual shifter, only it is shifted electrically.
    Autotrac II fluid contains friction modifiers that can be damaging to boxes that are not designed for them.
    Dec 2002
    Central FL
    My options list says I have Autotrac Active Transfer Case. How do I confirm this?
    The option code is NP1 (Electronic shift transfer case). Is this a contradiction?
    2008 GMC Sierra SLE 2500 HD
    Z71 4x4 Extended cab long bed
    265/70/17 oem aluminum wheels
    6.0 gasser with 6L90 tranny
    2007 Harley Davidson FXSTC
    Softtail Custom
    Too many mods to list
    2005 Contender 25 Open
    Yamaha 200 HPDI's
    Jan 2003
    Plainfield, IN
    TraceF,
    Check this link out from the January GM Techline:
    http://service.gm.com/gmtechlink/ima.../TLJan03e.html
    Looks like the only 2 options for the HD trucks are the NP1 and NP2 transfer cases. The NP1 is the pushbutton version while the NP2 is the manual version. I have the NP1 in my '03, and the service manual states that Dextron III ATF is the correct fluid.
    FYI, the autotrac transfer case is RPO code NP8. I had this in my '99 gasser. This transfer case takes the Autotrac II fluid sold at the GM dealer. There are several other listed, but this should clear up your, and anyone elses confusion.
    Mike
    Drive it like you stole it!<p>\'03 CC Silverado HD D/A Arrival Blue, ARE \'Z\' Topper, Line-X, TechTubes
    Dec 2002
    Central FL
    Thank you Mike.
    Softtail Custom
    Yamaha 200 HPDI's
    Jan 2002
    Angelus Oaks, CA
    Any thoughts on using Allison's Transynd in the transfer case?
    Aug 2002
    Enfield CT.
    Thats even better yet....
    03 GMC Allimax SLT extended cab shorty, totally loaded, black on dark pewter Hot Juice stacked on Bully Dog programed VA pressure box 33/12.50/16.5 BFGoodrich A/T KO\'s on 16.5X9.75 Center Line Outlaws, Kennedy Headlight power, AFE stage II intake, Dakota Digital pillar mount boost/EGT guages, ATS duals to follow ! There are 3 things you DO NOT ask a man to to test drive, his Lady, his Harley, and his Duramax ! Toddster@cox.net
    Apr 2000
    Northcoast of B.C.
    Diesel-dog;
    I use Petro-Can Syngear 75W-90 in the front and rear axles plus Shell Donax TG (Dexron III ATF)in the transfer case.
    1998 K2500HD ext. cab longbox<br />-Mag-Hytec differential cover
